Datasheet L9848 (STMicroelectronics) - 5
DescriptionOctal Configurable Low/High Side Driver
Pages / Page27 / 5 — L9848. List of figures
File Format / SizePDF / 325 Kb
L9848 List of figures
link to page 6 link to page 6 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 21 link to page 22 link to page 22 link to page 23 link to page 23 link to page 24 link to page 25
L9848 List of figures List of figures
Figure 1. Block diagram . 6 Figure 2. Pin connection (top view) . 6 Figure 3. DO loading for disable time measurement . 12 Figure 4. Output loading for slew rate measurement . 12 Figure 5. Output turn on/off delays and slew rates . 12 Figure 6. SPI input/output slew ratest . 13 Figure 7. SPI timing diagram . 13 Figure 8. L9848 with external components . 21 Figure 9. L9848 as mirror axis control motor drivers . 22 Figure 10. L9848 as mirror motor and bulb driver . 22 Figure 11. L9848 as window lift relay and mirror motor driver . 23 Figure 12. L9848 as bipolar stepper motor driver . 23 Figure 13. L9848 driving approach for 3 bipolar stepper-motors in sequential mode for climate applications as window lift relay and mirror motor driver. 24 Figure 14. SO-28 mechanical data and package dimensions . 25 5/27 Document Outline Table 1. Device summary 1 Block diagram and pin description Figure 1. Block diagram Figure 2. Pin connection (top view) Table 2. Pin description 2 Electrical specifications 2.1 Absolute maximum ratings Table 3. Absolute maximum ratings 2.2 Operation conditions Table 4. Operation conditions 2.3 Thermal data Table 5. Thermal data 2.4 Electrical characteristcs 2.4.1 DC characteristics Table 6. Electrical characteristcs 2.4.2 AC characteristics Table 7. AC characteristics Figure 3. DO loading for disable time measurement Figure 4. Output loading for slew rate measurement Figure 5. Output turn on/off delays and slew rates Figure 6. SPI input/output slew ratest Figure 7. SPI timing diagram 3 Functional description 3.1 General features 3.2 Outputs - Common characteristics 3.2.1 Output 1-4 3.2.2 Output 5-6 3.2.3 Output7-8 3.3 Main power input (VDD) 3.4 Discrete inputs (IN5-6) 3.5 Serial peripheral interface (SPI) 3.5.1 Serial data output (DO) 3.5.2 Serial data input (DI) 3.5.3 Chip select (CS) 3.5.4 Serial clock (SCLK) 3.6 SPI DI input command register Table 8. Bit command register definition Table 9. Command register logic definition 3.7 Fault operation Table 10. Fault register definition Table 11. Fault logic definition 3.7.1 Initial fault register SPI Cycle 3.7.2 Incandescent lamp outputs 3.8 Configuration for Output1-6 3.8.1 Low side drivers 3.8.2 High side drivers 3.9 DRN1-6 susceptibility to negative voltage transients 3.10 Thermal shutdown 3.11 Charge pump usage 3.12 Waveshaping 3.13 POR register initialization 3.14 Abnormal voltage conditions 3.14.1 Reverse Battery 3.14.2 Maximum negative transients 3.14.3 Ground offsets 3.14.4 Loss of ground operation 4 Functional block diagram Figure 8. L9848 with external components 5 Application examples Figure 9. L9848 as mirror axis control motor drivers Figure 10. L9848 as mirror motor and bulb driver Figure 11. L9848 as window lift relay and mirror motor driver Figure 12. L9848 as bipolar stepper motor driver Figure 13. L9848 driving approach for 3 bipolar stepper-motors in sequential mode for climate applications as window lift relay and mirror motor driver 6 Package information Figure 14. SO-28 mechanical data and package dimensions 7 Revision history Table 12. Document revision history
