Datasheet LMC7221 (Texas Instruments) - 4
Manufacturer | Texas Instruments |
Description | Tiny CMOS Comparator with Rail-To-Rail Input and Open Drain Output |
Pages / Page | 24 / 4 — LMC7221. www.ti.com. 5.0V and 15.0V Electrical Characteristics … |
File Format / Size | PDF / 924 Kb |
LMC7221. www.ti.com. 5.0V and 15.0V Electrical Characteristics (continued). Boldface. Parameter. Test Conditions. LMC7221AI
LMC7221
SNOS748E – SEPTEMBER 1999 – REVISED MARCH 2013
www.ti.com 5.0V and 15.0V Electrical Characteristics (continued)
Unless otherwise specified, all limits ensured for TJ = 25°C, V+ = 5.0V and 15V, V− = 0V, VCM = VO = V+/2.
Boldface
limits apply at the temperature extremes.
Parameter Test Conditions LMC7221AI LMC7221BI Units Typ(1) Limit(2) Limit(2)
ISC Short Circuit Current Sinking (4) 45 mA (4) Limiting input pin current is only necessary for input voltages which exceed the absolute maximum input voltage rating.
Leakage Characteristics
TJ = 25°C
ILEAKAGE Output Leakage Current V+ = 2.7V VIN(+) = 0.5V 0.1 500 500 nA VIN(−) = 0V VOUT = 15V (1) Typical values represent the most likely parametric norm as determined at the time of characterization. Actual typical values may vary over time and will also depend on the application and configuration. The typical values are not tested and are not ensured on shipped production material. (2) All limits are specified by testing or statistical analysis.
AC Electrical Characteristics
Unless otherwise specified, all limits ensured for TJ = 25°C, V+ = 5V, V− = 0V, VCM = VO = V+/2.
Boldface
limits apply at the temperature extreme.
trise Rise Time f = 10 kHz, CL = 50 pF, (3) 0.3 μs Overdrive = 10 mV, 5 kΩ Pullup tfall Fall Time f = 10 kHz, CL = 50 pF, (3) 0.3 μs Overdrive = 10 mV, 5 kΩ Pullup tPHL Propagation Delay f = 10 kHz, CL = 50 pF, 10 mV 10 μs (High to Low) (4) 5 kΩ Pullup (3) 100 mV 4 V+ = 2.7V, f = 10 kHz, 10 mV 10 μs CL = 50 pF, 5 kΩ Pullup (3) 100 mV 4 tPLH Propagation Delay f = 10 kHz, CL = 50 pF, 10 mV 6 μs (Low to High) (4) 5 kΩ Pullup (3) 100 mV 4 V+ = 2.7V, f = 10 kHz, 10 mV 7 μs CL = 50 pF, 5 kΩ Pullup (3) 100 mV 4 (1) Typical values represent the most likely parametric norm as determined at the time of characterization. Actual typical values may vary over time and will also depend on the application and configuration. The typical values are not tested and are not ensured on shipped production material. (2) All limits are specified by testing or statistical analysis. (3) Do not short circuit the output to V+ when V+ is greater than 12V or reliability will be adversely affected. (4) Input offset voltage average drift is calculated by dividing the accelerated operating life VOS drift by the equivalent operational time. This represents worst case input conditions and includes the first 30 days of drift. 4 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LMC7221 Document Outline FEATURES Applications DESCRIPTION Connection Diagram Absolute Maximum Ratings Operating Ratings 2.7V Electrical Characteristics 5.0V and 15.0V Electrical Characteristics Leakage Characteristics AC Electrical Characteristics Typical Performance Characteristics Application Information BENEFITS OF THE LMC7221 TINY COMPARATOR Size Height Simplified Board Layout Low Supply Current Wide Voltage Range Digital Outputs Representing Signal Level Open Drain Output Driving LEDs (Light Emitting Diodes) Input range to Beyond Rail to Rail Zero Crossing Detector Low Input Currents and High Input Impedance Direct Sensor Interfacing LOW VOLTAGE OPERATION OPEN DRAIN OUTPUT Output Stage OUTPUT SHORT CIRCUIT CURRENT INPUT PROTECTION LAYOUT CONSIDERATIONS PUSH-PULL OUTPUTS, DUAL VERSIONS ADDITIONAL 5-Pin SOT-23 TINY DEVICES SPICE MACROMODEL Revision History
