Datasheet LMC7221 (Texas Instruments) - 6
Description | Tiny CMOS Comparator with Rail-To-Rail Input and Open Drain Output |
Pages / Page | 24 / 6 — LMC7221. www.ti.com. Typical Performance Characteristics (continued). … |
File Format / Size | PDF / 924 Kb |
LMC7221. www.ti.com. Typical Performance Characteristics (continued). Response Time. vs. Various Input Overdrives −tPHL. Figure 9
LMC7221
SNOS748E – SEPTEMBER 1999 – REVISED MARCH 2013
www.ti.com Typical Performance Characteristics (continued) Response Time Response Time vs. vs Various Input Overdrives −tPHL Various Input Overdrives −tPHL Figure 9. Figure 10. Input Bias Current Input Bias Current vs. vs. Common Mode Voltage Common Mode Voltage Figure 11. Figure 12. Input Bias Current Input Bias Current vs. vs. Common Mode Voltage Temperature Figure 13. Figure 14.
6 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LMC7221 Document Outline FEATURES Applications DESCRIPTION Connection Diagram Absolute Maximum Ratings Operating Ratings 2.7V Electrical Characteristics 5.0V and 15.0V Electrical Characteristics Leakage Characteristics AC Electrical Characteristics Typical Performance Characteristics Application Information BENEFITS OF THE LMC7221 TINY COMPARATOR Size Height Simplified Board Layout Low Supply Current Wide Voltage Range Digital Outputs Representing Signal Level Open Drain Output Driving LEDs (Light Emitting Diodes) Input range to Beyond Rail to Rail Zero Crossing Detector Low Input Currents and High Input Impedance Direct Sensor Interfacing LOW VOLTAGE OPERATION OPEN DRAIN OUTPUT Output Stage OUTPUT SHORT CIRCUIT CURRENT INPUT PROTECTION LAYOUT CONSIDERATIONS PUSH-PULL OUTPUTS, DUAL VERSIONS ADDITIONAL 5-Pin SOT-23 TINY DEVICES SPICE MACROMODEL Revision History
