Datasheet MAX4289 (Analog Devices) - 3
Description | 1.0V Micropower, SOT23, Operational Amplifier |
Pages / Page | 9 / 3 — 1.0V Micropower, SOT23, Operational Amplifier. MAX4289. ELECTRICAL … |
File Format / Size | PDF / 287 Kb |
1.0V Micropower, SOT23, Operational Amplifier. MAX4289. ELECTRICAL CHARACTERISTICS (continued). PARAMETER. SYMBOL. CONDITIONS. MIN
1.0V Micropower, SOT23, Operational Amplifier MAX4289 ELECTRICAL CHARACTERISTICS (continued)
(VCC = 3V, VCM = 0, VOUT = VCC/2, RL tied to VCC/2, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Sourcing/sinking VCC = 1.0V 0.6 Output Short-Circuit Current IOUT mA current VCC = 3.0V 19 Power-Up Time tPU 300 µs Input Capacitance CIN 3.0 pF Gain-Bandwidth Product GBW 17 kHz Phase Margin θM 80 d egr ees Gain Margin GM 10 dB Slew Rate SR 6 V/ms Capacitive-Load Stability AVCL = +1V/V, no sustained oscillations 200 pF Settling Time to 0.1% tS AVCL = +1V/V, no sustained oscillations 75 µs
Note 1:
All specifications are 100% production tested at TA = +25°C. Temperature specification limits are guaranteed by design.
Typical Operating Characteristics
(VCC = 3V, VCM = 0, RL to VCC/2, TA = +25°C, unless otherwise noted.)
INPUT OFFSET VOLTAGE INPUT OFFSET VOLTAGE SUPPLY CURRENT vs. TEMPERATURE vs. INPUT COMMON-MODE VOLTAGE vs. TEMPERATURE
16 0.8 0.8 14 0.6 0.6 MAX4289 toc01 VCC = 3V MAX4289 toc02 MAX4289 toc03 12 0.4 0.4 µA) 10 0.2 0.2 VCC = 1V 8 0 0 6 -0.2 -0.2 SUPPLY CURRENT ( 4 -0.4 INPUT OFFSET VOLTAGE (mV) -0.4 INPUT OFFSET VOLTAGE (mV) 2 -0.6 -0.6 0 -0.8 -0.8 -40 -20 0 20 40 60 80 100 0 0.5 1.0 1.5 2.0 2.5 3.0 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) INPUT COMMON-MODE VOLTAGE (V) TEMPERATURE (°C)
_______________________________________________________________________________________ 3
