Datasheet PE4259 (pSemi) - 3
Manufacturer | pSemi |
Description | SPDT High Power UltraCMOS 10 MHz–3.0 GHz RF Switch |
Pages / Page | 10 / 3 — PE4259. Figure 3. Pin Configuration (Top View). Table 4. Absolute Maximum … |
File Format / Size | PDF / 575 Kb |
PE4259. Figure 3. Pin Configuration (Top View). Table 4. Absolute Maximum Ratings. Symbol Parameter/Condition Min. Max. Unit
PE4259
Product Specification
Figure 3. Pin Configuration (Top View) Table 4. Absolute Maximum Ratings Symbol Parameter/Condition Min Max Unit
VDD Power supply voltage –0.3 4.0 V V V DD+ I Voltage on any DC input –0.3 V 0.3 Storage temperature TST –65 150 °C range Operating temperature TOP –40 85 °C range PIN Input power (50Ω) +34* dBm ESD Voltage (HBM,
Table 2. Pin Descriptions
ML_STD 883 Method 2000 V VESD 3015.7)
Pin No. Pin Name Description
ESD Voltage (MM, 100 V JEDEC, JESD22-A114-B) 1 RF1* RF port 1. Note: * To maintain optimum device performance, do not exceed Max PIN at Ground connection. Traces should be desired operating frequency (see Figure 4). 2 GND physically short and connected to ground Exceeding absolute maximum ratings may cause plane for best performance. permanent damage. Operation should be restricted to 3 RF21 RF port 2. the limits in the Operating Ranges table. Operation 4 CTRL Switch control input, CMOS logic level. between operating range maximum and absolute 5 RFC1 RF common. This pin supports two interface options: Single-pin control mode. A nominal 3-volt
Figure 4. Maximum Input Power
supply connection is required. 6 CTRL or VDD Complementary-pin control mode. A complementary CMOS control signal to CTRL is supplied to this pin. Bypassing on this pin is not required in this mode. Note: * All RF pins must be DC blocked with an external series capacitor or held at 0 VDC.
Table 3. Operating Ranges Parameter Min Typ Max Unit
VDD Power supply voltage 1.8 3.0 3.3 V IDD Power supply current 9 20 µA (VDD = 3V, VCNTL = 3V) Control voltage high 0.7x VDD V Control voltage low 0.3x VDD V
Latch-Up Avoidance
Unlike conventional CMOS devices, UltraCMOS
Moisture Sensitivity Level
devices are immune to latch-up. The Moisture Sensitivity Level rating for the PE4259 in the SC70 package is MSL1.
Electrostatic Discharge (ESD) Precautions
When handling this UltraCMOS device, observe the
Switching Frequency
same precautions that you would use with other ESD- The PE4259 has a maximum 25 kHz switching rate. sensitive devices. Although this device contains circuitry to protect it from damage due to ESD, precautions should be taken to avoid exceeding the specified rating. Document No. DOC-03694-5 │ www.psemi.com ©2005-2023 pSemi Corporation All rights reserved.
Page 3 of 10
