Datasheet MH-441D (Winsen) - 3
ManufacturerWinsen
DescriptionNDIR Infrared CH4 Sensor
Pages / Page7 / 3 — MH-441D NDIR Infrared CH4 Sensor. 1. Introduction. 2.Features. …
File Format / SizePDF / 552 Kb
MH-441D NDIR Infrared CH4 Sensor. 1. Introduction. 2.Features. 3.Applications. 4.Main Parameters
MH-441D NDIR Infrared CH4 Sensor 1 Introduction 2.Features 3.Applications 4.Main Parameters
Zhengzhou Winsen Electronics Technology Co., Ltd. www.winsen-sensor.com
MH-441D NDIR Infrared CH4 Sensor 1. Introduction
MH-440D infrared gas sensor is a miniature universal intelligent sensor, which adopts NDIR theory to detect concentration of CH4 in air and has good selectivity, stable performance, long life, also is independent of Oxygen. The inside temperature sensor could be used for temperature compensation. This miniature infrared gas sensor is developed by the tight integration of mature infrared absorbing gas detection technology, micro machine workout and superior circuit design. It is convenient in use and also instead of catalytic component directly, widely used in various occasions with methane and explosion hazard gas.
2.Features
➢ High sensitivity, high resolution, fast response ➢ Output method: UART, analog voltage signal ➢ Temperature compensation, excellent linear output ➢ Excellent stability, Long lifespan ➢ Anti-poisons, anti-vapor interference ➢ Can replace catalytic type gas sensor directly
3.Applications
Widely used for HVAC refrigeration, air monitoring indoor, industrial-process control and safety protection, agriculture and animal husbandry.
4.Main Parameters
Fig1.Technical Parameters Part Number MH-441D Detection Gas methane Detection Range 0~10%VOL(selectable, refer fig2.) Working Voltage 3.6~5V DC (Require powered by safety barrier) Average Current <85mA Interface Level 3.0V UART Output Signal 0.4~2.0V DC(Require output by safety barrier) Warm-up time 3 min Response time T90<30 seconds Working Temperature -20°C ~ 60°C Working Humidity 0~95%RH(no condensation) Sizes Φ20×22.4mm Weight 35g Lifetime >5 years Defense Grade IP54 Power, communication Ui=7.5VDC,Ii=265mA, terminal Intrinsic safety Pi=0.5W, Ci=10 μF, Li=0mH Tel: 86-371-67169097 Fax: 86-371-60932988 1 Email: sales@winsensor.com
