Low-Cost, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage ReferencesELECTRICAL CHARACTERISTICS—MAX6103, VOUT = 3.0V (VIN = 5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITS Output Voltage VOUT TA = +25°C 2.988 3.000 3.012 V 0°C to +70°C 65 Output Voltage Temperature TCVOUT ppm/°C Coefficient (Notes 2, 3) -40°C to +85°C 75 ∆VOUT/ Line Regulation (VOUT + 0.2V) ≤ VIN ≤ 12.6V 400 µV/V ∆VIN Sourcing: 0 ≤ IOUT ≤ 5mA 0.9 ∆VOUT/ Load Regulation mV/mA ∆IOUT Sinking: -2mA ≤ IOUT ≤ 0 6.0 VIN - Dropout Voltage (Note 5) IOUT = 1mA 50 200 mV VOUT Short to GND 110 OUT Short-Circuit Current ISC mA Short to IN 12 MAX6100–MAX6107 ∆VOUT/ ppm/ Long-Term Stability 1000hr at +25°C 50 time 1000hr Output Voltage Hysteresis ∆VOUT/ 130 ppm (Note 4) cycle DYNAMIC CHARACTERISTICS f = 0.1Hz to 10Hz 35 µVP-P Noise Voltage eOUT f = 10Hz to 10kHz 40 µVRMS ∆VOUT/ Ripple Rejection VIN = 5V ±100mV, f = 120Hz 76 dB ∆VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 115 µs INPUT CHARACTERISTICS V Supply Voltage Range VIN Guaranteed by line-regulation test OUT + 12.6 V 0.2 Quiescent Supply Current IIN 90 125 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 4 8 µA/V 6_______________________________________________________________________________________
