Datasheet MAX6035 (Analog Devices) - 4
DescriptionHigh-Supply-Voltage, Precision Voltage Reference in SOT23
Pages / Page15 / 4 — High-Supply-Voltage, Precision Voltage Reference in SOT23. ELECTRICAL …
File Format / SizePDF / 795 Kb
High-Supply-Voltage, Precision Voltage Reference in SOT23. ELECTRICAL CHARACTERISTICS—MAX6035_AUR30 (3.0V) (continued)
High-Supply-Voltage, Precision Voltage Reference in SOT23 ELECTRICAL CHARACTERISTICS—MAX6035_AUR30 (3.0V) (continued)
(VIN = 5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Short to GND 27 OUT Short-Circuit Current ISC mA Short to IN -4 TA = 0°C to +125°C IOUT = 10µA 1.75
MAX6035
Dropout Voltage (Note 7) VIN - VOUT IOUT = 10µA 1.9 V TA = -40°C to +125°C IOUT = 10mA 2.25 Thermal Hysteresis (Note 5) ∆V OU T /cycl e 135 ppm ppm/ Long-Term Stability ∆VOUT/time 1000hr at +25°C 120 1000hr
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 25 µVP-P Output Noise Voltage en f = 10Hz to 1kHz 25 µVRMS ∆V Ripple Rejection OUT/ ∆ VIN = 5V ±100mV, f = 120Hz 80 dB VIN COUT = 50pF 40 Turn-On Settling Time tR VOUT = 0.1% of final value µs COUT = 1µF 250 Capacitive-Load Stability COUT 0 5 µF (Note 6)
INPUT CHARACTERISTICS
TA = 0°C to +125°C, inferred from line regulation 4.75 33 and dropout voltage Supply Voltage Range VIN V TA = -40°C to +125°C, inferred from line 4.9 33 regulation and dropout voltage Quiescent Current Supply IIN 73 95 µA Change in Supply Current ∆IIN/∆VIN 4.9V ≤ VIN ≤ 33V 0.4 0.7 µA/V
ELECTRICAL CHARACTERISTICS—MAX6035_AUR50 (5.0V)
MAX6035A (0.2%) 4.9900 5.0000 5.0100 Output Voltage VOUT TA = +25°C V MAX6035B (0.5%) 4.9750 5.0000 5.0250 MAX6035A 20 TA = 0°C to +70°C MAX6035B 50 Output Voltage MAX6035A 25 Temperature Coefficient TCVOUT TA = -40°C to +85°C ppm/°C MAX6035B 65 (Note 3) MAX6035A 30 TA = -40°C to +125°C MAX6035B 75 TA = + 25°C 7.5 25 Line Regulation (Note 4) ∆VOUT/∆VIN (VOUT + 2V) ≤ VOUT ≤ 33V µV/V TA = - 40°C to + 125°C 8 40
4 _______________________________________________________________________________________
