Datasheet CRCW0402, CRCW0603, CRCW0805, CRCW1206, CRCW1210, CRCW1218, CRCW2010, CRCW2512, D10/CRCW0402, D11/CRCW0603, D12/CRCW0805, D25/CRCW1206 (Vishay) - 5
ManufacturerVishay
DescriptionLead (Pb)-Bearing Thick Film Chip Resistors
Pages / Page10 / 5 — D/CRCW. FUNCTIONAL PERFORMANCE Single Pulse. Continuous Pulse. Pulse …
File Format / SizePDF / 135 Kb
D/CRCW. FUNCTIONAL PERFORMANCE Single Pulse. Continuous Pulse. Pulse Voltage
D/CRCW FUNCTIONAL PERFORMANCE Single Pulse Continuous Pulse Pulse Voltage
D/CRCW
www.vishay.com Vishay
Axis Title 1000 10000 CRCW2512 CRCW1218 CRCW2010 100 CRCW1210 e ) D25/CRCW1206 in (W D12/CRCW0805 1000 D11/CRCW0603 10 2nd l D10/CRCW0402 ne ne se Load ul 1st li 2nd li P 1 - x. 100 ^ P ma 0.1 0.01 10 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 10 100 t - Pulse Duration (s) i Maximum pulse load, single pulse; applicable if P → 0 and n < 1000 and Uˆ = Uˆ max.; for permissible resistance change equivalent to 8000 h operation
Continuous Pulse
Axis Title 1000 10000 CRCW2512 ) CRCW1218 CRCW2010 ine 100 CRCW1210 D25/CRCW1206 2nd l D12/CRCW0805 1000 e Load (W D11/CRCW0603 ls 10 u D10/CRCW0402 P ne ne 1st li 2nd li 1 nuous 100 onti C - x. 0.1 ^ P ma 0.01 10 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 10 100 t - Pulse Duration (s) i Maximum pulse load, continuous pulses; applicable if P ≤ P (ϑamb) and Uˆ = Uˆ max.; for permissible resistance change equivalent to 8000 h operation
Pulse Voltage
Axis Title 2000 10000 CRCW2512 1800 CRCW2010 D25/CRCW1206, CRCW1210, CRCW1218 1600 ) D12/CRCW0805 D11/CRCW0603 ine (V 1400 D10/CRCW0402 1000 1200 2nd l ltage o ne ne 1000 se V 1st li 2nd li ul 800 P - 100 x. 600 ^ U ma 400 200 0 10 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 10 t - Pulse Duration (s) i Maximum pulse voltage, single and continuous pulses; applicable if Pˆ = Pˆ max.; for permissible resistance change equivalent to 8000 h operation Revision: 09-Jul-2024
5
Document Number: 20008 For technical questions, contact: thickfilmchip@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
