Datasheet MAX6078A, MAX6078B (Analog Devices)
DescriptionLow-Power, Low-Drift, Low-Noise Voltage Reference
Pages / Page18 / 1 — here. MAX6078A/MAX6078B. Low-Power, Low-Drift,. Low-Noise Voltage …
File Format / SizePDF / 3.2 Mb
here. MAX6078A/MAX6078B. Low-Power, Low-Drift,. Low-Noise Voltage Reference. General Description. Benefits and Features
Datasheet MAX6078A, MAX6078B Analog Devices
link to page 17 Click
here
to ask an associate for production status of specific part numbers.
MAX6078A/MAX6078B Low-Power, Low-Drift, Low-Noise Voltage Reference General Description Benefits and Features
The MAX6078 precision voltage reference family provides ● ±0.04% Initial Accuracy low drift and low noise at a maximum power supply current ● 10ppm/°C (max) Temperature Drift of only 15µA. Low-frequency noise is less than 12µVP-P ● 12µVP-P Noise (0.1Hz to 10Hz) at 2.5V (2.5V output voltage option) and the temperature coeffi- ● 15µA Supply Current cient of the output voltage is less than 10ppm/°C. ● Long-Term Drift: 16ppm (typ, 4000hrs) The reference output can sink and source up to 3mA of ● 3mA Source/Sink Load Current load current and the top grade provides an initial accu- ● Filter Option Reduces High-Frequency Noise racy of 0.04%. The low-drift and low-noise specifications ● 100mV Dropout Voltage enable enhanced system accuracy, making these devices ● 1.5mm x 1.3mm (0.5mm pitch), 6-Bump WLP and ideal for high-precision industrial applications. A noise re- 2mm x 3mm, 8-Pin TDFN-EP Packages duction (NR) input pin allows connection of an external ca- ● Voltage Output Options: 1.25V, 2.048V, 2.5V, 3.0V, pacitor to reduce wideband noise. Available output volt- 3.3V, 4.096V, and 5.0V ages include 1.25V, 2.048V, 2.5V, 3.0V, 3.3V, 4.096V, and 5.0V.
Simplified Block Diagram
The tiny, 6-bump WLP and small, 8-pin TDFN-EP pack- IN ages are suitable for systems where circuit board area is limited. The operating input voltage can range from 2.3V MAX6078 to 5.5V. Operation is specified over the extended industri- OUTS al temperature range of -55°C to +125°C. OUTF
Applications
NR BANDGAP ● High-Accuracy Industrial and Process Control EN ● Precision Instrumentation ● High-Resolution ADCs and DACs GND ● Portable and Handheld Systems
Ordering Information
appears at end of data sheet. 19-100579; Rev 3; 6/23 © 2023 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. One Analog Way, Wilmington, MA 01887 U.S.A. | Tel: 781.329.4700 | © 2023 Analog Devices, Inc. All rights reserved. Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 8 TDFN 8 WLP Electrical Characteristics – 2.5V Electrical Characteristics – 2.5V (continued) Electrical Characteristics – 3.0V Electrical Characteristics – 3.0V (continued) Electrical Characteristics – 3.3V Electrical Characteristics – 3.3V (continued) Electrical Characteristics – 5.0V Electrical Characteristics – 5.0V (continued) Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configurations 6 WLP 8 TDFN-EP Pin Description Pin Description (continued) Typical Operating Circuit Detailed Description Wideband Noise Reduction (NR) Output Bypassing Turn-On Time Output Force and Sense Shutdown Thermal Hysteresis Applications Information Precision Current Source Ordering Information Revision History
