Datasheet MAX6061, MAX6062, MAX6063, MAX6064, MAX6065, MAX6066, MAX6067, MAX6068 (Analog Devices) - 9
DescriptionPrecision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References
Pages / Page16 / 9 — Precision, Micropower, Low-Dropout,. High-Output-Current, SOT23 Voltage …
File Format / SizePDF / 559 Kb
Precision, Micropower, Low-Dropout,. High-Output-Current, SOT23 Voltage References. MAX6061–MAX6068
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References MAX6061–MAX6068
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References MAX6061–MAX6068 ELECTRICAL CHARACTERISTICS—MAX6065, VOUT = 5.000V
(VIN = +5.2V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6065A (0.2%) 4.990 5.000 5.010 Output Voltage VOUT TA = +25°C V MAX6065B (0.4%) 4.980 5.000 5.020 Output Voltage Temperature MAX6065A 6 20 TCV ppm/°C Coefficient (Note 2) OUT MAX6065B 6 30 ∆V Line Regulation OUT/ ∆ (VOUT + 0.2V) ≤ VIN ≤ 12.6V 180 550 µV/V VIN ∆V Sourcing: 0 ≤ IOUT ≤ 5mA 0.5 0.9 Load Regulation OUT/ ∆ mV/mA IOUT Sinking: -2mA ≤ IOUT ≤ 0 2.4 8.0 V Dropout Voltage (Note 4) IN - IOUT = 1mA 50 200 mV VOUT Short to GND 25 OUT Short-Circuit Current ISC mA Short to IN 25 ∆V ppm/ Long-Term Stability OUT/ 1000hr at +25°C 62 time 1000hr Output Voltage Hysteresis ∆VOUT/ 130 ppm (Note 3) cycle
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 60 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 60 µVRMS ∆V Ripple Rejection OUT/ ∆ VIN = 5V ±100mV, f = 120Hz 65 dB VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 300 µs
INPUT CHARACTERISTICS
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 90 125 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 3.2 8.0 µA/V
Note 1:
All devices are 100% production tested at TA = +25°C and are guaranteed by design for TA = TMIN to TMAX, as specified.
Note 2:
Temperature Coefficient is measured by the “box” method, i.e., the maximum ∆VOUT is divided by the maximum ∆T.
Note 3:
Temperature Hysteresis is defined as the change in +25°C output voltage before and after cycling the device from TMIN to TMAX.
Note 4:
Dropout voltage is the minimum input voltage at which VOUT changes ≤ 0.2% from VOUT at VIN = 5.0V (VIN = 5.5V for MAX6065).
_______________________________________________________________________________________ 9
