Datasheet ADRF5030 (Analog Devices) - 7
Description100 MHz to 20 GHz, Non-Reflective, Silicon SPDT Switch
Pages / Page13 / 7 — ADRF5030. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. Figure 3. Pin …
File Format / SizePDF / 752 Kb
ADRF5030. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. Figure 3. Pin Configuration (Top View)
ADRF5030 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS Figure 3 Pin Configuration (Top View)
link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 Data Sheet
ADRF5030 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS Figure 3. Pin Configuration (Top View) Table 6. Pin Function Descriptions Pin No. Mnemonic Description
1, 2, 4, 5, 6, 7, 9, 10, 13, 16, 17, GND Ground. These pins must be connected to the RF/DC ground of the PCB. 19, 20 3 RFC RF Common Port. This pin is DC-coupled to 0 V. No DC-blocking capacitor is necessary when the RF line potential is equal to 0 V DC. See Figure 4 for the interface schematic. 8 RF1 RF Port 1. This pin is DC-coupled to 0 V. No DC-blocking capacitor is necessary when the RF line potential is equal to 0 V DC. See Figure 4 for the interface schematic. 11 VDD Positive Supply Voltage. See Figure 6 for the interface schematic. 12 CTRL Control Input Voltage. See for the truth table. See Figure 5 for the interface schematic. 14 EN Enable Input Voltage. See for the truth table. See Figure 5 for the interface schematic. 15 VSS Negative Supply Voltage. See Figure 7 for the interface schematic. 18 RF2 RF Port 2. This pin is DC-coupled to 0 V. No DC-blocking capacitor is necessary when the RF line potential is equal to 0 V DC. See Figure 4 for the interface schematic EPAD Exposed Pad. The exposed pad must be connected to the RF/DC ground of the PCB.
analog.com Rev. 0 | 7 of 13
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curves Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADRF5030 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input and Output Power Supply Applications Information Recommendations for Printed Circuit Board Design Outline Dimensions Ordering Guide Notes
