Datasheet MAX6012 (Analog Devices) - 3
DescriptionPrecision, Low-Power, Low-Dropout, SOT23-3 Voltage References
Pages / Page16 / 3 — MAX6012/MAX6021/MAX6025/. MAX6030/MAX6041/MAX6045/MAX6050. Electrical …
File Format / SizePDF / 2.3 Mb
MAX6012/MAX6021/MAX6025/. MAX6030/MAX6041/MAX6045/MAX6050. Electrical Characteristics—MAX6021. PARAMETER. SYMBOL. CONDITIONS. MIN
MAX6012/MAX6021/MAX6025/ MAX6030/MAX6041/MAX6045/MAX6050 Electrical Characteristics—MAX6021 PARAMETER SYMBOL CONDITIONS MIN
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
2.043 2.048 2.053 V MAX6021A -0.24 0.24 % Output Voltage VOUT TA = +25°C 2.040 2.048 2.056 V MAX6021B -0.39 0.39 % TA = 0°C to +70°C 6 15 MAX6021A Output Voltage Temperature TA = -40°C to +85°C 6 20 Coefficient (Note 2) VOUT ppm/°C TA = 0°C to +70°C 6 25 MAX6021B TA = -40°C to +85°C 6 30 Line Regulation ΔVOUT/ ΔV 2.5V ≤ VIN ≤ 12.6V 10 100 μV/V IN Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 500μA 0.12 0.55 ΔI μV/μA OUT Sinking: -500μA ≤ IOUT ≤ 0 0.18 0.70 Short to GND 4 OUT Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis (Note 3) 130 ppm Long-Term Stability ΔVOUT/ time 1000hr at TA = +25°C 50 ppm/ 1000h
DYNAMIC
f = 0.1Hz to 10Hz 35 μVp-p Noise Voltage eOUT f = 10Hz to 10kHz 105 μVRMS Ripple Rejection ΔVOUT/ ΔV VIN = 5V ±100mV, f = 120Hz 84 dB IN Turn-On Settling Time t To VOUT = 0.1% of final value, R COUT = 50pF 70 μs Capacitive-Load Stability Range COUT Note 4 0 2.2 nF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test 2.5 12.6 V Quiescent Supply Current IIN 27 35 μA Change in Supply Current IIN/VIN 2.5V ≤ VIN ≤ 12.6V 0.8 2.0 μA/V www.analog.com Analog Devices │ 3
