Datasheet MAX6012 (Analog Devices) - 7
DescriptionPrecision, Low-Power, Low-Dropout, SOT23-3 Voltage References
Pages / Page16 / 7 — MAX6012/MAX6021/MAX6025/. MAX6030/MAX6041/MAX6045/MAX6050. Electrical …
MAX6012/MAX6021/MAX6025/. MAX6030/MAX6041/MAX6045/MAX6050. Electrical Characteristics—MAX6045. PARAMETER. SYMBOL. CONDITIONS. MIN
MAX6012/MAX6021/MAX6025/ MAX6030/MAX6041/MAX6045/MAX6050 Electrical Characteristics—MAX6045 PARAMETER SYMBOL CONDITIONS MIN
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
4.491 4.500 4.509 V Output Voltage VOUT TA = +25°C -0.20 0.20 % Output Voltage Temperature TA = 0°C to +70°C 6 15 Coefficient (Note 2) VOUT ppm/°C TA = -40°C to +85°C 6 20 Line Regulation ΔVOUT/ ΔV (VOUT + 0.2V) ≤ VIN ≤ 12.6V 25 160 μV/V IN Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 500μA 0.16 0.80 ΔI μV/μA OUT Sinking: -500μA ≤ IOUT ≤ 0 0.22 1.00 Dropout Voltage VIN- (Note 5) V IOUT = 500μA 100 200 mV OUT Short to GND 4 OUT Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis ΔVOUT/ (Note 3) time 130 ppm Long-Term Stability ΔVOUT/ time 1000hr at TA = +25°C 50 ppm/ 1000h
DYNAMIC
f = 0.1Hz to 10Hz 110 μVp-p Noise Voltage eOUT f = 10Hz to 10kHz 215 μVRMS Ripple Rejection ΔVOUT/ ΔV VIN = 5V ±100mV, f = 120Hz 76 dB IN Turn-On Settling Time t To VOUT = 0.1% of final value, R COUT = 50pF 180 μs Capacitive-Load Stability Range COUT Note 4 0 2.2 nF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 27 35 μA Change in Supply Current IIN/VIN 2.5V ≤ VIN ≤ 12.6V 0.8 2.0 μA/V www.analog.com Analog Devices │ 7
