Datasheet MAX6029 (Analog Devices) - 6
DescriptionUltra-Low-Power Precision Series Voltage Reference
Pages / Page15 / 6 — Electrical Characteristics—MAX6029_41 (VOUT = 4.096V). PARAMETER. SYMBOL. …
File Format / SizePDF / 430 Kb
Electrical Characteristics—MAX6029_41 (VOUT = 4.096V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. OUTPUT
Electrical Characteristics—MAX6029_41 (VOUT = 4.096V) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
MAX6029 Ultra-Low-Power Precision Series Voltage Reference
(VIN = 4.3V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
MAX6029EUK 4.0899 4.0960 4.1021 Output Voltage VOUT TA = +25°C V MAX6029ESA 4.088 4.096 4.104 Output Voltage Temperature TCV Coefficient OUT (Notes 2, 3) 30 ppm/°C Line Regulation ΔVOUT/ΔVIN VIN = 4.3V to 12.6V 30 310 µV/V IOUT = 0 to 4mA 0.1 0.6 Load Regulation ΔVOUT/ΔIOUT µV/µA IOUT = 0 to -1mA 2.5 8.5 IOUT = 0 100 Dropout Voltage (Note 5) VIN - VOUT mV IOUT = 4mA 200 Output Short-Circuit Current ISC 60 mA Long-Term Stability ΔVOUT/time 1000 hours at +25°C 150 ppm Thermal Hysteresis (Note 4) 140 ppm
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 72 µVP-P Noise Voltage eOUT f = 10Hz to 1kHz 210 µVRMS Ripple Rejection ΔVOUT/ΔVIN VIN = 4.3V ±200mV, f = 120Hz 36 dB Turn-On Settling Time tR To VOUT = 0.1% of final value 1.2 ms
INPUT
Supply Voltage Range VIN 4.3 12.6 V Supply Current IIN 8.75 µA Change in Supply Current IIN/VIN VIN = 4.3V to 12.6V 1.5 µA/V www.maximintegrated.com Maxim Integrated | 6
