Datasheet MAX6029 (Analog Devices) - 9
Description | Ultra-Low-Power Precision Series Voltage Reference |
Pages / Page | 15 / 9 — Typical Operating Characteristics (continued). LINE REGULATION. LOAD … |
File Format / Size | PDF / 430 Kb |
Typical Operating Characteristics (continued). LINE REGULATION. LOAD REGULATION. (VOUT = 2.048V). (VOUT = 3V)
MAX6029 Ultra-Low-Power Precision Series Voltage Reference
(VIN = 2.5V for MAX6029EUK21, VIN = 3.2V for MAX6029EUK30, and VIN = 5.2V for MAX6029EUK50, IOUT = 0, TA = +25°C, unless otherwise noted.)
LINE REGULATION LOAD REGULATION LINE REGULATION (VOUT = 2.048V) (VOUT = 3V) (VOUT = 3V)
2.04792 3.0055 3.00180 2.04790 3.0050 MAX6029 toc10 2.04788 MAX6029 toc11 MAX6029 toc12 3.0045 3.00175 2.04786 3.0040 2.04784 3.00170 3.0035 2.04782 3.0030 2.04780 3.00165 OUTPUT VOLTAGE (V) 3.0025 2.04778 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 2.04776 3.0020 3.00160 2.04774 3.0015 2.04772 3.0010 3.00155 2.5 4.0 5.5 7.0 8.5 10.0 11.5 13.0 -2 -1 0 1 2 3 4 5 6 7 3 4 5 6 7 8 9 10 11 12 13 INPUT VOLTAGE (V) OUTPUT CURRENT (mA) INPUT VOLTAGE (V)
LOAD REGULATION LINE REGULATION POWER-SUPPLY REJECTION RATIO vs. (VOUT = 5V) (VOUT = 5V) FREQUENCY (VOUT = 2.048V)
5.0050 5.00080 0 5.0045 5.00078 -10 MAX6029 toc13 5.0040 MAX6029 toc14 MAX6029 toc15 5.00076 5.0035 -20 5.00074 5.0030 5.00072 -30 5.0025 PSRR (dB) 5.00070 5.0020 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) -40 5.0015 5.00068 -50 5.0010 5.00066 5.0005 5.00064 -60 -2 -1 0 1 2 3 4 5 6 7 5 6 7 8 9 10 11 12 13 0.1 1 10 100 1000 OUTPUT CURRENT (mA) INPUT VOLTAGE (V) FREQUENCY (kHz)
POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO LINE-TRANSIENT RESPONSE vs. FREQUENCY (VOUT = 3V) vs. FREQUENCY (VOUT = 5V) (VOUT = 2.048V)
MAX6029 toc18 0 0 3V -5 VIN -10 200mV/div MAX6029 toc16 MAX6029 toc17 -10 AC-COUPLED -15 -20 2.5V -20 -30 -25 PSRR (dB) PSRR (dB) -30 -40 -35 2.048V VOUT -40 -50 200mV/div -45 AC-COUPLED -60 -50 0.1 1 10 100 1000 0.1 1 10 100 1000 200μs/div FREQUENCY (kHz) FREQUENCY (kHz) www.maximintegrated.com Maxim Integrated | 9
