Datasheet MAX6138 (Analog Devices)
Description0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages
Pages / Page13 / 1 — here. MAX6138. 0.1%, 25ppm, SC70 Shunt Voltage Reference. with Multiple …
here. MAX6138. 0.1%, 25ppm, SC70 Shunt Voltage Reference. with Multiple Reverse Breakdown Voltages. General Description. Features
Datasheet MAX6138 Analog Devices
link to page 12 Click
here
for production status of specific part numbers.
MAX6138 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages General Description Features
The MAX6138 is a precision, two-terminal shunt mode, ● Ultra-Small 3-Pin SC70 Package bandgap voltage reference available in fixed reverse ● 0.1% (max) Initial Accuracy breakdown voltages of 1.2205V, 2.048V, 2.5V, 3.0V, 3.3V, 4.096V, and 5.0V. Ideal for space-critical applications, the ● 25ppm/°C (max) Temperature Coefficient Guaranteed MAX6138 is offered in the subminiature 3-pin SC70 sur- Over -40°C to +85°C Temperature Range face-mount package (1.8mm x 1.8mm), 50% smaller than ● Wide Operating Current Range: 60μA to 15mA comparable devices in SOT23 surface-mount packages. ● Low 28μVRMS Output Noise (10Hz to 10kHz) Laser-trimmed resistors ensure precise initial accuracy. ● 1.2205V, 2.048V, 2.5V, 3.0V, 3.3V, 4.096V, and 5.0V With a 25ppm/°C temperature coefficient, the device is Fixed Reverse Breakdown Voltages offered in three grades of initial accuracy ranging from 0.1% to 0.5%. The MAX6138 has a 60μA to 15mA shunt- ● No Output Capacitors Required current capability with low-dynamic impedance, ensuring ● Stable with Capacitive Loads stable reverse breakdown voltage accuracy over a wide range of operating temperatures and currents.
Selector Guide
The MAX6138 does not require an external stabilizing
OUTPUT
capacitor while ensuring stability with capacitive loads.
PART TEMP PIN- RANGE PACKAGE VOLTAGE
The MAX6138 is a higher precision device in a smaller
(V)
package than the LM4040/LM4050. MAX6138_EXR12-T -40°C to +85°C 3 SC70-3 1.2205
Applications
MAX6138_EXR21-T -40°C to +85°C 3 SC70-3 2.0480 MAX6138_EXR25-T -40°C to +85°C 3 SC70-3 2.5000 ● Portable, Battery-Powered Equipment ● Notebook Computers MAX6138_EXR30-T -40°C to +85°C 3 SC70-3 3.0000 ● Cell Phones MAX6138_EXR33-T -40°C to +85°C 3 SC70-3 3.3000 ● Industrial Process Control MAX6138_EXR41-T -40°C to +85°C 3 SC70-3 4.0960 MAX6138_EXR50-T -40°C to +85°C 3 SC70-3 5.0000
Ordering Information appears at end of data sheet. Pin Configuration Typical Operating Circuit
VS TOP VIEW RS ISHUNT + ILOAD ILOAD + 1 VR
MAX6138
3 N.C.* ISHUNT - 2
MAX6138 SC70
*PIN 3 MUST BE LEFT FLOATING OR CONNECTED TO PIN 2. 19-2090; Rev 3; 12/19
