Datasheet MAX17579, MAX17580 (Analog Devices) - 7
Description | 4.5V to 60V, 300mA High-Efficiency, Synchronous, Inverting Output DC-DC Converters |
Pages / Page | 26 / 7 — Typical Operating Characteristics (continued) |
File Format / Size | PDF / 1.6 Mb |
MAX17579/MAX17580 4.5V to 60V, 300mA High-Efficiency, Synchronous, Inverting Output DC-DC Converters
(VGND = 0V, CVCC = 2.2μF, CBST = 0.1μF, CSS = 5600pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at TA = +25°C. All voltages are referenced to GND, unless otherwise noted.) www.analog.com Analog Devices | 7 Document Outline General Description Applications Benefits and Features Simplified Application Circuit Absolute Maximum Ratings Package Information TDFN-EP Electrical Characteristics Electrical Characteristics (continued) Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configuration MAX17579, MAX17580 Pin Description Functional Diagrams MAX17579/MAX17580 Block Diagram Detailed Description Switching Frequency and External Clock Synchronization Linear Regulator (VCC) Operating Input-Voltage Range Overcurrent Protection (OCP)/Hiccup Mode RESET Output Prebiased Output Thermal-Shutdown Protection Applications Information Inductor Selection Load Current Capability (IOUT(MAX)) Input Capacitor Selection Output Capacitor Selection Soft-Start Capacitor Selection Adjusting Output Voltage Setting the Input Undervoltage-Lockout Level Soft-Start Inductive Output Short-Circuit Protection Power Dissipation PCB Layout Guidelines Typical Application Circuits -5V Typical Application Circuits Typical Application Circuits (continued) -15V Typical Application Circuit Ordering Information Revision History
