Datasheet PMC150, PMS150 (Padauk) - 10
Manufacturer | Padauk |
Description | 8-bit OTP Type IO Controller |
Pages / Page | 56 / 10 — PMC150/PMS150 Series. 8-bit OTP Type IO Controller Pin Name Pin & Buffer … |
PMC150/PMS150 Series. 8-bit OTP Type IO Controller Pin Name Pin & Buffer IO. PA7 ST /. CMOS IO. PA6 Description Type ST /
PA7 ST /
CMOS IO
CMOS The functions of this pin can be bit 7 of port A. It can be configured as digital input
or two-state output, with pull-high resistor.
This pin can be used to wake-up system during sleep mode; however, wake-up
function is also disabled if bit 7 of padier register is “0”.
The functions of this pin can be bit 6 of port A. It can be configured as digital input
function is also disabled if bit 6 of padier register is “0”.
The functions of this pin can be:
(1) Bit 5 of port A. It can be configured as digital input or open-drain output. IO
PA5/PRST# ST /
CMOS Please notice that there is no pull-high resistor in this pin.
(2) Hardware reset.
function is also disabled if bit 5 of padier register is “0”.
Please put 33Ω resistor in series to have high noise immunity when this pin is in
input mode. IO
PA4 ST /
CMOS IO
PA3 ST /
CMOS The functions of this pin can be bit 4 of port A. It can be configured as digital input
This pin can be used to wake up system during sleep mode; however, wake-up
function from this pin is disabled when bit 4 of padier register is “0”.
The functions of this pin can be bit 3 of port A. It can be configured as digital input
function from this pin is disabled when bit 3 of padier register is “0” .
(1) Bit 0 of port A. It can be configured as digital input or two-state output, with IO
PA0/INT0 ST /
CMOS pull-high resistor.
(2) External interrupt line 0. Both rising edge and falling edge are accepted to
request interrupt service.
function from this pin is also disabled when bit 0 of padier register is “0”. NC -No Connection VDD Positive power GND Ground Notes: IO: Input/ Output; ST: Schmitt Trigger input; Analog: Analog input pin; CMOS: CMOS voltage level ©Copyright 2018, PADAUK Technology Co. Ltd Page 10 of 56 PDK-DS-PMX150-EN-V108 – Dec. 11, 2018
