Datasheet MAX480 (Analog Devices) - 4
Description | High Precision, Low-Voltage, Micropower Op Amp |
Pages / Page | 7 / 4 — High-Precision, Low-Voltage,. Micropower Op Amp. MAX480. ELECTRICAL … |
File Format / Size | PDF / 232 Kb |
High-Precision, Low-Voltage,. Micropower Op Amp. MAX480. ELECTRICAL CHARACTERISTICS. MAX480C. MAX480E. MAX480M. PARAMETER SYMBOL
High-Precision, Low-Voltage, Micropower Op Amp MAX480 ELECTRICAL CHARACTERISTICS
(VS = ±1.5V to ±15V, TA = TMIN to TMAX, unless otherwise noted.)
MAX480C MAX480E MAX480M PARAMETER SYMBOL CONDITIONS UNITS MIN TYP MAX MIN TYP MAX MIN TYP MAX
Input Offset VOS 40 220 50 250 70 300 µV Voltage Input Offset TCVOS (Note 2) 0.3 2.0 0.3 2.0 0.3 2.0 µV/°C Voltage Drift Input Offset IOS VCM = 0 0.2 2.0 5.0 0.3 2.0 7.0 0.5 2.0 10.0 nA Current Input Bias IB VCM = 0 1 3 15 2 5 20 3 7 30 nA Current RL = 100kΩ 350 950 350 800 60 400 VS = ±15V, R 130 400 130 400 45 240 V = ±10V L = 10kΩ Large-Signal R 55 150 30 110 A L = 2kΩ 55 125 VO V/mV Voltage Gain V+ = 5V, RL = 100kΩ 50 360 50 280 35 200 V- = 0, 1V < VO < 4V RL = 10kΩ 30 150 30 140 22 110 Input Voltage V+ = 5V, V- = 0 0/3.5 0/3.5 0/3.5 IVR V Range VS = ±15V (Note 1) -15/13.5 -15/13.5 -15/13.5 RL = 10kΩ ±13.5 ±14 ±13.5 ±14 ±13.5 ±13.7 VO VS = ±15V RL = 2kΩ ±9.5 ±11.8 ±10.5 ±11.8 ±10.5 ±11.5 9.5 V Output Voltage V+ = 5V, V- = 0 VOH 3.9 4.1 3.9 4.1 Swing RL = 2kΩ 3.9 4.1 V+ = 5V, V- = 0 VOL 100 500 100 500 µV RL = 10kΩ 100 500 V+ = 5V, V- = 0, 85 110 85 110 80 105 0 < VCM < 3.5V Common-Mode CMRR dB Rejection Ratio VS = ±15V, 90 120 90 120 85 115 -15V < VCM < 13.5V Power-Supply PSRR 1.0 12 1.0 12 3.2 15 µV/V Rejection Ratio VS = ±1.5V 12 25 13 25 15 25 Supply Current ISY µA VS = ±15V 16 30 17 30 19 30
Note 1:
Guaranteed by CMRR test.
Note 2:
Guaranteed by design.
_______________________________________________________________________________________ 3
