Datasheet AZ9431Q (Diodes)
ManufacturerDiodes
DescriptionAutomotive Compliant 1.24v Adjustable Precision Shunt Regulator
Pages / Page9 / 1 — AZ9431Q. AUTOMOTIVE COMPLIANT 1.24V ADJUSTABLE PRECISION SHUNT REGULATOR. …
File Format / SizePDF / 897 Kb
AZ9431Q. AUTOMOTIVE COMPLIANT 1.24V ADJUSTABLE PRECISION SHUNT REGULATOR. Description. Pin Assignments
Datasheet AZ9431Q Diodes
AZ9431Q AUTOMOTIVE COMPLIANT 1.24V ADJUSTABLE PRECISION SHUNT REGULATOR Description Pin Assignments
SOT23 The AZ9431Q series are three-terminal adjustable shunt regulators with guaranteed thermal stability over a full operation range. These ICs feature sharp turn-on characteristics, low temperature coefficient, REF 1 and low output impedance, which make them ideal substitutes for zener diodes in automotive and high-reliability applications requiring 3 ANODE an improvement in zener performance. CATHODE 2 The output voltage can be set to any value between 1.24V and 18V with two external resistors. (Top View) The AZ9431Q precision reference is offered in 0.5% and 1.0% voltage tolerance. The AZ9431Q are available in SOT23 that are qualified to AEC-Q100 standards for high reliability and are PPAP capable.
Typical Applications Circuit Features
Wide Programmable Precise Output Voltage from 1.24V to 18V Temperature Range -40°C to +125°C Reference Voltage Tolerance at +25°C 0.5% AZ9431AQSA-7 1% AZ9431BQSA-7 High Stability Under Capacitive Load Low Temperature Deviation: 3mV Typical Low Equivalent Full-Range Temperature Coefficient: 20PPM/°C Low Dynamic Output Resistance: 0.05Ω Typical High-Sink Current Capacity from 0.1mA to 100mA Low Output Noise Shunt Regulator Wide Operating Range of -40°C to +125°C Green Molding
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3) The AZ9431Q series are suitable for automotive applications requiring specific change control; these parts are AEC-Q100 qualified, PPAP capable, and manufactured in IATF 16949 certified facilities. https://www.diodes.com/quality/product-definitions/
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AZ9431Q 1 of 9 January 2022 Document number: DS40953 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
