Datasheet ZTL431, ZTL432 (Diodes) - 6
ManufacturerDiodes
DescriptionCost Effective Adjustable Precision Shunt Regulator
Pages / Page13 / 6 — ZTL431/ZTL432. DC Test Circuits. Notes. Stability Boundary. www.diodes.com
File Format / SizePDF / 577 Kb
ZTL431/ZTL432 DC Test Circuits Notes Stability Boundary www.diodes.com
Deviation of reference input voltage, VDEV, is defined as the VMAX maximum variation of the reference input voltage over the full temperature range. The average temperature coefficient of the reference input voltage, VREF is defined as: VREF(ppm/°C) = VDEV × 1,000,000 VREF(T1-T2) V MIN The dynamic output impedance, Rz, is defined as: VDEV = VMAX - VMIN RZ = ΔVZ ΔIZ When the device is programmed with two external resistors, R1 and R2, (Figure 2), the dynamic output impedance of the overall circuit, R'z, is defined as: R'Z = RZ (1 + R1 ) R2
Stability Boundary
The ZTL431 and ZTL432 are stable with a range of capacitive loads. A zone of instability exists as demonstrated in the typical characteristic graph on page 4. The graph shows typical conditions. To ensure reliable stability, a capacitor of 4.7nF or greater is recommended between anode and cathode. ZTL431/ZTL432 6 of 13 January 2021 Document number: DS33263 Rev. 19 - 3
www.diodes.com
© Diodes Incorporated Document Outline Marking Information Package Outline Dimensions Package Outline Dimensions (Cont.) Suggested Pad Layout Suggested Pad Layout (Cont.)
