Datasheet TL431LI, TL432LI (Texas Instruments) - 4
| Manufacturer | Texas Instruments |
| Description | Programmable Shunt Regulator with Optimized Reference Current |
| Pages / Page | 35 / 4 — TL431LI. TL432LI. www.ti.com. 7 Specifications. 7.1 Absolute Maximum … |
| File Format / Size | PDF / 968 Kb |
TL431LI. TL432LI. www.ti.com. 7 Specifications. 7.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 7.2 ESD Ratings. VALUE
TL431LI TL432LI
SLVSDQ6A – JULY 2018 – REVISED NOVEMBER 2018
www.ti.com 7 Specifications 7.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
VKA Cathode Voltage(2) 37 V IKA Continuos Cathode Current Range –10 18 mA II(ref) Reference Input Current –5 10 mA TJ Operating Junction Temperature Range –40 150 C Tstg Storage Temperature Range –65 150 C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) All voltage values are with respect to ANODE, unless otherwise noted.
7.2 ESD Ratings VALUE UNIT
Human body model (HBM), per ANSI/ESDA/JEDEC JS-001pins(1) ±2000 Electrostatic V(ESD) V discharge Charged-device model (CDM), per JEDEC specification JESD22- ±1000 VC101(2) ±1000 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
7.3 Thermal Information TL43xLI THERMAL METRIC(1) DBZ UNIT 3 PINS
RθJA Junction-to-ambient thermal resistance 371.7 C/W RθJC(top) Junction-to-case (top) thermal resistance 145.9 C/W RθJB Junction-to-boardthermal resistance 104.7 C/W ψJT Junction-to-top characterization resistance 23.9 C/W ψJB Junction-to-board characterization resistance 102.9 C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953.
7.4 Recommended Operating Conditions
See (1)
MIN MAX UNIT
VKA Cathode Voltage VREF 36 V IKA Continuous Cathode Current Range 1 15 mA TL43xLIxC 0 70 C TA Operating Free-Air Temperature TL43xLIxI –40 85 C TL43xLIxQ –40 125 C (1) Maximum power dissipation is a function of TJ(max), θJA, and TA. The maximum allowable power dissipation at any allowable ambient temperature is PD = (TJ(max) – TA)/θJA. Operating at the absolute maximum TJ of 150°C can affect reliability. 4 Submit Documentation Feedback Copyright © 2018, Texas Instruments Incorporated Product Folder Links: TL431LI TL432LI Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Thermal Information 7.4 Recommended Operating Conditions 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Temperature Coefficient 8.2 Dynamic Impedance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.4 Device Functional Modes 9.4.1 Open Loop (Comparator) 9.4.2 Closed Loop 10 Applications and Implementation 10.1 Application Information 10.2 Typical Applications 10.2.1 Comparator With Integrated Reference 10.2.1.1 Design Requirements 10.2.1.2 Detailed Design Procedure 10.2.1.3 Application Curve 10.2.2 Precision Constant Current Sink 10.2.2.1 Design Requirements 10.2.2.2 Detailed Design Procedure 10.2.3 Shunt Regulator/Reference 10.2.3.1 Design Requirements 10.2.3.2 Detailed Design Procedure 10.2.3.3 Application Curve 10.2.4 Isolated Flyback with Optocoupler 10.2.4.1 Design Requirements 10.3 System Examples 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Related Links 13.2 Documentation Support 13.2.1 Device Nomenclature 13.2.2 Related Documentation 13.3 Receiving Notification of Documentation Updates 13.4 Community Resources 13.5 Trademarks 13.6 Electrostatic Discharge Caution 13.7 Glossary 14 Mechanical, Packaging, and Orderable Information
