Datasheet TL432LI (Texas Instruments) - 8
ManufacturerTexas Instruments
DescriptionAdjustable precision shunt regulator with optimized reference current (pin layout: RKA)
Pages / Page35 / 8 — TL431LI. TL432LI. www.ti.com. Typical Characteristics (continued). Figure …
File Format / SizePDF / 968 Kb
TL431LI. TL432LI. www.ti.com. Typical Characteristics (continued). Figure 12. Stability Boundary Conditions for All TL431LI,
TL431LI TL432LI www.ti.com Typical Characteristics (continued) Figure 12 Stability Boundary Conditions for All TL431LI,
TL431LI TL432LI
SLVSDQ6A – JULY 2018 – REVISED NOVEMBER 2018
15 150 Ω A VKA = Vref B VKA = 5 V IKA 12 C VKA = 10 V + t - mA C V L BATT Stable Region en − 9 e Curr od 6 ath - C TEST CIRCUIT FOR CURVE A AIK 3 IKA 0 R1 = 10 kΩ 150 Ω 0.001 0.01 0.1 1 10 CL - Load Capacitance - µF C To Lpy 43 CL The areas under the curves represent conditions that may cause the + device to oscillate. For curves B and C, R2 and V+ are adjusted to R2 VBATT establish the initial VKA and IKA conditions, with CL = 0. VBATT and CL − then are adjusted to determine the ranges of stability.
Figure 12. Stability Boundary Conditions for All TL431LI, TL432LI Devices
TEST CIRCUIT FOR CURVES B, C, AND D
Figure 13. Test Circuits for Stability Boundary Conditions
8 Submit Documentation Feedback Copyright © 2018, Texas Instruments Incorporated Product Folder Links: TL431LI TL432LI Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Thermal Information 7.4 Recommended Operating Conditions 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Temperature Coefficient 8.2 Dynamic Impedance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.4 Device Functional Modes 9.4.1 Open Loop (Comparator) 9.4.2 Closed Loop 10 Applications and Implementation 10.1 Application Information 10.2 Typical Applications 10.2.1 Comparator With Integrated Reference 10.2.1.1 Design Requirements 10.2.1.2 Detailed Design Procedure 10.2.1.3 Application Curve 10.2.2 Precision Constant Current Sink 10.2.2.1 Design Requirements 10.2.2.2 Detailed Design Procedure 10.2.3 Shunt Regulator/Reference 10.2.3.1 Design Requirements 10.2.3.2 Detailed Design Procedure 10.2.3.3 Application Curve 10.2.4 Isolated Flyback with Optocoupler 10.2.4.1 Design Requirements 10.3 System Examples 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Related Links 13.2 Documentation Support 13.2.1 Device Nomenclature 13.2.2 Related Documentation 13.3 Receiving Notification of Documentation Updates 13.4 Community Resources 13.5 Trademarks 13.6 Electrostatic Discharge Caution 13.7 Glossary 14 Mechanical, Packaging, and Orderable Information
