Datasheet ZR4040-5 (Diodes)
ManufacturerDiodes
DescriptionPrecision 5.0 Volt Micropower Voltage Reference
Pages / Page5 / 1 — NOT RECOMMENDED FOR NEW DESIGN. USE LM4040. ZR4040-5. PRECISION 5.0 VOLT …
File Format / SizePDF / 429 Kb
NOT RECOMMENDED FOR NEW DESIGN. USE LM4040. ZR4040-5. PRECISION 5.0 VOLT MICROPOWER VOLTAGE REFERENCE. Description
Datasheet ZR4040-5 Diodes
NOT RECOMMENDED FOR NEW DESIGN USE LM4040 ZR4040-5 PRECISION 5.0 VOLT MICROPOWER VOLTAGE REFERENCE Description Pin Assignments
The DIODES™ ZR4040-5 uses a bandgap circuit design to achieve a SOT23 Package Suffix - F precision micropower voltage reference of 5.0 volts. The device is available in a small outline surface mount package, ideal for applications where space saving is important, as well as packages for through hole requirements. The ZR4040-5 design provides a stable voltage without an external capacitor and is stable with capacitive loads. The ZR4040-5 is recommended for operation between 60μA and 15mA and so is ideally suited for low power and battery powered applications. Top View Pin 1 Floating or Connected to Pin 2 Excellent performance is maintained to an absolute maximum of 25mA, however the rugged design and 20 volt processing allows the E-Line, 3 Pins, Rev Package Suffix - R reference to withstand transient effects and currents up to 200mA. Superior switching capability allows the device to reach stable operating conditions in only a few microseconds.
Features
OBSOLETE Small Outline SOT23 Package No Stabilizing Capacitor Required Bottom View Typical TC 20ppm/°C Pin 3 Floating or Connected to Pin 1 Typical Slope Resistance 0.33Ω 2% and 1% Tolerance Automotive Temperature Range Operating Current 60μA to 15mA Transient Response, Stable in Less than 10μs
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3) For automotive applications requiring specific change Typical Application Circuit control (i.e. parts qualified to AEC-Q100/101/104/200, PPAP capable, and manufactured in IATF 16949 certified facilities), please contact us or your local Diodes representative. https://www.diodes.com/quality/product-definitions/ Applications
Battery powered and portable equipment Metering and measurement systems Instrumentations Test equipment Data acquisition systems Precision power supplies Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. ZR4040-5 1 of 5 May 2022 Document number: DS32179 Rev. 5 - 3
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
