Datasheet ZR4040-4.1 (Diodes) - 2
Manufacturer | Diodes |
Description | 4.096V Low Knee Current voltage reference |
Pages / Page | 5 / 2 — ZR4040-4.1. Absolute Maximum Ratings. Parameter. Rating. Unit. Electrical … |
File Format / Size | PDF / 414 Kb |
ZR4040-4.1. Absolute Maximum Ratings. Parameter. Rating. Unit. Electrical Characteristics. Symbol. Condition. Min. Typ. Max. Tol. (%)
ZR4040-4.1 Absolute Maximum Ratings
(Voltages to GND, unless otherwise stated.)
Parameter Rating Unit
Reverse Current 25 mA Forward Current 25 mA Operating Temperature -40 to +85 °C Storage Temperature -55 to +125 °C Power Dissipation (TAMB = +25°C) 330 mW SOT23
(Test condition: TAMB = +25°C, unless otherwise specified.)
Symbol Parameter Condition Min. Typ. Max. Tol. (%) Unit
4.05 4.096 4.14 1 VR Reverse Breakdown Voltage IR = 150µA V 4.01 4.096 4.18 2 IMIN Minimum Operating Current — — 25 60 — µA IR Recommended Operating Current — 0.06 — 15 — mA Average Reverse Breakdown Voltage T (*) C — 20 100 — ppm/°C Temperature Coefficient IR(MIN) to IR(MAX) R (†) S Slope Resistance — 0.55 2 — Ω IR = 1mA ZR Reverse Dynamic Impedance f = 100Hz — 0.4 1.2 — Ω IAC = 0.1IR I E R = 1mA N Wideband Noise Voltage — 90 — — µV(rms) f = 10Hz to 10kHz Notes: (*) (VR(MAX) – VR(MIN)) x 1000000 TC = VR x (T(MAX) – T(MIN)) Note: VR(MAX) - VR(MIN) is the maximum deviation in reference voltage measured over the full operating temperature range. (†) VR Change (IR(MIN) to IR(MAX)) RS = IR(MAX) – IR(MIN))
ZR4040-4.1 2 of 5 May 2022 Document number: DS32171 Rev. 6 - 3
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
