Datasheet AWSCR-CPLA (Abracon)
ManufacturerAbracon
DescriptionMiniature Ceramic Resonator
Pages / Page6 / 1 — Miniature Ceramic Resonator. AWSCR-CPLA. 6.0 x 3.0 x 1.8mm. RoHS/RoHS II …
File Format / SizePDF / 467 Kb
Miniature Ceramic Resonator. AWSCR-CPLA. 6.0 x 3.0 x 1.8mm. RoHS/RoHS II Compliant. MSL Level = 1. Features. Applications
Datasheet AWSCR-CPLA Abracon
Miniature Ceramic Resonator AWSCR-CPLA
Request Samples Check Inventory
6.0 x 3.0 x 1.8mm RoHS/RoHS II Compliant MSL Level = 1 Features Applications
• I ndustry standard footprint • Metering systems • Low resonance impedance • Remote control • Built-in capacitance options • Microprocessor • Wide operating temperatures in extended industry • Industrial control range • Electric appliances
Key Electrical Specifications Parameters Minimum Typical Maximum Units Notes
Frequency Range 1.84 12.00 MHz 100 1.84 MHz-2.99 MHz Resonant Impedance (Ro) 50 Ω 3.00 MHz-3.49 MHz 30 3.50 MHz-12.00 MHz 30 1.84 MHz-8.00 MHz Other options: 10, 15, 22, 33, 39, 47 (Tol 1pF± 20%) Standard Built-in Capacitance (C1=C2) pF 15 8.01 MHz-12.00 MHz Other options: 10, 22, 30, 33, 39, 47 (Tol 1pF± 20%) Frequency Tolerance -0.5 0.5 % -0.3 0.3 % 2.00-8.00 MHz Frequency Stability -0.2 0.2 % 8.01-12.00 MHz Withstanding Voltage 100 V DC, 5s max (1) D.C. Voltage 6 V Voltage Rating (2) A.C. Voltage 15 Vp-p Insulation Resistance (Ri) 500 MΩ 10V, 1 min Operation Temperature -40 +85 °C Storage Temperature -55 +85 °C Aging Rate (Fosc)* -0.1 0.1 % From Initial Value *Components shall be left in a chamber of +85±2°C for 1000 hours, then measured after leaving in natural Condition for 1 hours. 5101 H idden Creek Ln Spicewood TX 78669 ABRACON IS Phone: 512-371-6159 | Fax: 512-351-8858
REVISED: 08-08-24
ISO9001-2015 For terms and conditions of sales, please visit: CERTIFIED www.abracon.com Document Outline AWSCR-XX.XXCPLA-CXX-T4 Rev B.pdf
