Datasheet MC74AC125, MC74ACT125 (ON Semiconductor) - 8
ManufacturerON Semiconductor
DescriptionQuad 3-State Buffer with Low Enable
Pages / Page9 / 8 — PACKAGE DIMENSIONS. TSSOP−14 WB. SCALE 2:1. 14X REF. 2X L/2. −U−. PIN 1. …
File Format / SizePDF / 245 Kb
PACKAGE DIMENSIONS. TSSOP−14 WB. SCALE 2:1. 14X REF. 2X L/2. −U−. PIN 1. IDENT. DETAIL E. MILLIMETERS. INCHES. DIM MIN. MAX. MIN. −V−. J J1
PACKAGE DIMENSIONS TSSOP−14 WB SCALE 2:1 14X REF 2X L/2 −U− PIN 1 IDENT DETAIL E MILLIMETERS INCHES DIM MIN MAX MIN −V− J J1
MECHANICAL CASE OUTLINE
CASE 948G 14 ISSUE C DATE 17 FEB 2016 1
SCALE 2:1 14X REF K
NOTES: 1. DIMENSIONING AND TOLERANCING PER 0.10 (0.004) M T U S V S ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 0.15 (0.006) T U S 3. DIMENSION A DOES NOT INCLUDE MOLD FLASH, PROTRUSIONS OR GATE BURRS. MOLD FLASH OR GATE BURRS SHALL NOT
N
EXCEED 0.15 (0.006) PER SIDE. 0.25 (0.010)
14 8
4. DIMENSION B DOES NOT INCLUDE
2X L/2
INTERLEAD FLASH OR PROTRUSION.
M
INTERLEAD FLASH OR PROTRUSION SHALL NOT EXCEED 0.25 (0.010) PER SIDE.
B
5. DIMENSION K DOES NOT INCLUDE DAMBAR
L
PROTRUSION. ALLOWABLE DAMBAR
−U− N PIN 1
PROTRUSION SHALL BE 0.08 (0.003) TOTAL
IDENT. F
IN EXCESS OF THE K DIMENSION AT MAXIMUM MATERIAL CONDITION.
1 7
6. TERMINAL NUMBERS ARE SHOWN FOR
DETAIL E
REFERENCE ONLY. 7. DIMENSION A AND B ARE TO BE DETERMINED AT DATUM PLANE −W−. 0.15 (0.006) T U S
K A MILLIMETERS INCHES K1 DIM MIN MAX MIN MAX −V− A
4.90 5.10 0.193 0.200
B
4.30 4.50 0.169 0.177
J J1
ÇÇÇ ÉÉÉ
C
−−− 1.20 −−− 0.047
D
0.05 0.15 0.002 0.006 ÇÇÇ ÉÉÉ
F
0.50 0.75 0.020 0.030
SECTION N−N G
0.65 BSC 0.026 BSC
H
0.50 0.60 0.020 0.024
J
0.09 0.20 0.004 0.008
J1
0.09 0.16 0.004 0.006
−W− C K
0.19 0.30 0.007 0.012
K1
0.19 0.25 0.007 0.010
L
6.40 BSC 0.252 BSC 0.10 (0.004)
M
0 _ 8 _ 0 _ 8 _
−T− SEATING D G H DETAIL E PLANE GENERIC MARKING DIAGRAM* RECOMMENDED SOLDERING FOOTPRINT*
14 XXXX 7.06 XXXX ALYWG 1 G 1 A = Assembly Location L = Wafer Lot Y = Year 0.65 W = Work Week PITCH G = Pb−Free Package (Note: Microdot may be in either location) *This information is generic. Please refer to 14X 0.36 14X device data sheet for actual part marking. 1.26 Pb−Free indicator, “G” or microdot “G”, may DIMENSIONS: MILLIMETERS or may not be present. Some products may *For additional information on our Pb−Free strategy and soldering not follow the Generic Marking. details, please download the
onsemi
Soldering and Mounting Techniques Reference Manual, SOLDERRM/D.
DOCUMENT NUMBER: 98ASH70246A
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: TSSOP−14 WB PAGE 1 OF 1 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
