Datasheet AWSCR-CV (Abracon)
ManufacturerAbracon
Description3.7 x 3.1mm Industrial Grade Built-in Capacitance Ceramic Resonator
Pages / Page3 / 1 — 3.7 x 3.1mm Industrial Grade Built-in Capa citance Ceramic Resonator …
3.7 x 3.1mm Industrial Grade Built-in Capa citance Ceramic Resonator AWSCR-CV. Pb in ceramic, exemption (7c-I)
Datasheet AWSCR-CV Abracon
3.7 x 3.1mm Industrial Grade Built-in Capa citance Ceramic Resonator AWSCR-CV A
AWSCR-CV
Pb in ceramic, exemption (7c-I) RoHS/RoHS II compliant
3.7 x 3.1 x 1.0mm
Moisture Sensitivity Level (MSL) – This product is not Moisture Sensitive - MSL = 1 FEATURES: APPLICATIONS:
• Low resonant impedance • Remote controls, Microprocessor clocks, Mobile phones, • Built-in load capacitors DVD & CD-Roms, Electric appliances • IR reflow capable • Consumer electronics
STANDARD SPECIFICATIONS: Parameters Minimum Typical Maximum Units Notes
Frequency Range 8.00 13.00 MHz 16.00 60.00 30 8.00 MHz – 13.00 MHz 60 13.01 MHz – 15.99 MHz Resonant Impedance (Ro) 40 Ω 16.00 MHz – 20.00 MHz 40 20.01 MHz – 25.99 MHz 40 26.00 MHz – 60.00 MHz 22 – 20% 22 22 + 20% 8.00 MHz – 13.00 MHz 22 – 20% 22 22 + 20% 13.01 MHz – 15.99 MHz Standard Built-in Capacitance (C1=C2) 22 – 20% 22 22 + 20% pF 16.00 MHz – 20.00 MHz 10 – 20% 10 10 + 20% 20.01 MHz – 25.99 MHz 5 – 20% 5 5 + 20% 26.00 MHz – 60.00 MHz Frequency Tolerance @25 ºC -0.5 0.5 % Frequency Stability @ -25ºC to +85ºC -0.4 0.4 8.00 MHz – 13.00 MHz -0.3 0.3 % 13.01 MHz – 60.00 MHz Withstanding Voltage 50 V DC , 1 min Rating Voltage (1) D.C.Voltage 6 V (2) A.C. Voltage 15 Vp-p. Insulation Resistance 100 MΩ 10V, 1min Operation Temperature -25 85 ºC Storage Temperature -55 85 ºC Aging Rate (Fosc) (10 years) -0.3 0.3 %
OPTIONS AND PART IDENTIFICATION:
AWSCR – X.XXCV - C -
Frequency Load Capacitance Packaging
Contact ABRACON T: 1000pcs/Reel Frequency in MHz for Built-in Capacitance options Visit www.abracon.com for Terms & Conditions of Sale
Revised: 04.25.14
ABRACON IS ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED tel 949-546-8000 | fax 949-546-8001 | www.abracon.com
