Datasheet AWSCR-CELA (Abracon)
ManufacturerAbracon
DescriptionSMD Ceramic Resonator with Internal Capacitors
Pages / Page6 / 1 — Miniature Ceramic Resonator. 3.2 x 1.3 x 1.0 mm. RoHS/RoHS II Compliant. …
File Format / SizePDF / 840 Kb
Miniature Ceramic Resonator. 3.2 x 1.3 x 1.0 mm. RoHS/RoHS II Compliant. Pb in ceramic, exemption (7c-I)
Datasheet AWSCR-CELA Abracon
Miniature Ceramic Resonator 3.2 x 1.3 x 1.0 mm
AWSCR-CELA
RoHS/RoHS II Compliant Pb in ceramic, exemption (7c-I) This product is not Moisture Sensitive - MSL = 1 Features Applications
Industry standard footprint
Metering systems
Low resonance impedance
Remote control
Built-in capacitance options
Microprocessor
Wide operating temperatures in extended
Industrial control industry range
Electric appliances
Electrical Specifications Parameters Min Typ. Max Units Notes
Frequency Range 8.00 12.00 MHz Resonant Impedance (Ro) 40 Ω 8.00 MHz - 12.00 MHz 15 Standard Built-in Capacitance (C1=C2) pF 8.00 MHz - 12.00 MHz Other options: 10, 22, 30, 33 (Tol 1pF ± 20%) Frequency Tolerance -0.5 0.5 % Temperature Coefficient of Oscillation Frequency (%) max. -0.2 0.2 % Oscillator Frequency drift (-40 oC to +85 ºC) Withstanding Voltage 50 V DC, 1 min max (1) D.C. Voltage 6 V Voltage Rating (2) A.C. Voltage 15 Vp-p Insulation Resistance (Ri) 500 MΩ 10V, 1 min Operation Temperature -40 +85 ºC Storage Temperature -55 +85 ºC Aging Rate max (Fosc) * For 10 years -0.2 0.2 % From Initial value * Components shall be left in a chamber of +85 oC ± 2 oC for 1000 hours, then measured after leaving in natural condition for 1 hour. 5101 Hidden Creek Ln Spicewood TX 78669 ABRACON IS Phone: 512-371-6159 | Fax: 512-351-8858
REVISED: 04-17-19
ISO9001-2015
LLC
For terms and conditions of sales, please visit: CERTIFIED www.abracon.com
