Datasheet ECS-SDR1 (ECS Inc.) - 2
Manufacturer | ECS Inc. |
Description | SMD One Port SAW Resonator |
Pages / Page | 2 / 2 — ECS-SDR1 Series. SMD ONE PORT SAW Resonator. DIMENSIONS (mm). Pin … |
File Format / Size | PDF / 421 Kb |
ECS-SDR1 Series. SMD ONE PORT SAW Resonator. DIMENSIONS (mm). Pin Connections. Figure 1). Figure 2). SOLDER PROFILE
ECS-SDR1 Series SMD ONE PORT SAW Resonator DIMENSIONS (mm) Pin Connections
#1 No Connect #2 Input #3 No Connect #4 Ground #5 No Connect #6 Output #7 No Connect #8 Ground
Figure 1)
Top, Side, End and Bottom views
Figure 2)
Land Pattern
SOLDER PROFILE
Peak solder Temp +260°C Max 10 sec Max. 2 Cycles Max. MSL 1, Lead Finish: Au
Figure 1)
Suggested Solder Profile
15351 West 109th Street
Lenexa, KS 66219
Phone: 913.782.7787
Fax: 913.782.6991
www.ecsxtal.com
