Datasheet FL5150 (ON Semiconductor) - 8
Manufacturer | ON Semiconductor |
Description | IGBT and MOSFET AC Phase Cut Dimmer Controller |
Pages / Page | 23 / 8 — The Recommended Operating Conditions table defines the conditions for … |
File Format / Size | PDF / 1.0 Mb |
The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended
operating conditions are specified to ensure optimal performance to the data sheet specifications. Fairchild does not
recommend exceeding them or designing to Absolute Maximum Ratings. Unless otherwise specified, refer to Figure 1 to
Figure 5. TA=25°C, ISHUNT=5 mA, and phase=60 Hz. Symbol Parameter Conditions Min. Typ. Max. Unit FL5150/60 Electrical Parameters (TA=25°C, Ishunt=5 mA, unless otherwise specified)
VS UVLO IQ Power Supply Shunt Regulator
Voltage Under-Voltage Lockout
(Power-on-Reset) VS to GND 16 17 18 VS to GND, Rising Enable
FL5160/50 9.2 9.5 9.8 VS to GND, Falling
Hysteresis Terminate DRV
Gate Pulse 0.5 VS to GND, Falling
Hysteresis Disable
FL5150/60 2.2 Quiescent Current VS to GND = 12 V VDD Supply Voltage VPW Control = 0 OCSen1VH
OCSen2VH Sense1&2 Clamp High IH = 350 µA OCSen1VL
OCSen2VL Sense1&2 Clamp Low IL = -350 µA ZCMonVH ZC Monitor Clamp High IH = 350 µA ZCMonVL ZC Monitor Clamp Low IH = -350 µA VDD OSC Internal Timer FL5160
FL5150 4.5 600 800 µA 5.0 5.5 V 4.0 V
V 4.0
-0.7 DIMCNISOURCE DIM Control Source Current VDIM Control = 0 DIMCNVFORCE DIM Control 100% Duty Cycle VDIM Control 194
161.7
9.4 200 166.7 171.7
10.0 VADC (8-Bit) DRVGVH DRV Gate High RADJ Open (VS=17 V) DRVGVL DRV Gate Low RADJ Connected to GND DRVGTLH DRV Gate L to H CLoad = 3 nF, 10 to 90% DRVGTHL DRV Gate H to L CLoad = 3 nF, 10 to 90% DMVL DIM Mode Logic Low
(Select Trailing Edge) VL DMVH DIM Mode Logic High
(Select Leading Edge) VH DIM Mode Source Current IDIM Mode DIM Mode Selection Time after
Under-Voltage lock Out Enable
Threshold FL5160 60 FL5150 72 FL5160, VDIM Control = 0 100 FL5150, VDIM Control = 0 120 LPMTEN LP Mode Enable Time OCVTH Over-Current Threshold,
Trailing Edge
RSENSE1,2 =1 M
I Q1DRAIN – Q2DRAIN I © 2016 Fairchild Semiconductor Corporation
FL5150/60 • 1.0 10.6 A 2.56 V 17.0 V
100 mV 150 250 ns 50 100 ns 1.0 V VDD -1.0
7 kHz V ADC Reference Voltage DMTSEL 206 VDD – 0.5 16.0 V
V VREFADC DMISOURCE V -0.7 VDIM Control = 0 V FL5150/60 — IGBT and MOSFET AC Phase Cut Dimmer Controller Recommended Operating Conditions V
10 13 A
ms Half Cycle
Phase Angle 0 to 43° 3.5 43° to 65° 2.9 65° to 86° 2.4 86° to 180° 2.0 ms V www.fairchildsemi.com
7
