Datasheet XN6543 (Panasonic) - 2
ManufacturerPanasonic
DescriptionSilicon NPN Epitaxial Planer Transistor
Pages / Page2 / 2 — Composite. Transistors. XN6543. PT. —. Ta. IC. —. VCE. IC. —. VBE. 240. …
File Format / SizePDF / 42 Kb
Composite. Transistors. XN6543. PT. —. Ta. IC. —. VCE. IC. —. VBE. 240. 30. 120. Ta=25˚C. VCE=8V. ). IB=250µA. 200. 25. 100. (mW. ). T. (mA. (mA. 25˚C. 160. 20. 200µA. 80. C. C. Ta=75˚C
Composite Transistors XN6543 PT — Ta IC — VCE IC — VBE 240 30 120 Ta=25˚C VCE=8V ) IB=250µA 200 25 100 (mW ) T (mA (mA 25˚C 160 20 200µA 80 C C Ta=75˚C
Composite Transistors XN6543 PT — Ta IC — VCE IC — VBE 240 30 120 Ta=25˚C VCE=8V ) IB=250µA 200 25 100 (mW ) T (mA (mA 25˚C 160 20 200µA 80 C C Ta=75˚C –25˚C 120 15 150µA 60 80 10 100µA 40 Collector current I Collector current I 40 5 20 Total power dissipation P 50µA 0 0 0 0 40 80 120 160 0 2 4 6 8 10 12 0 0.2 0.4 0.6 0.8 1.0 1.2 Ambient temperature Ta (˚C) Collector to emitter voltage VCE (V) Base to emitter voltage VBE (V) VCE(sat) — IC hFE — IC fT — IC 10 240 12 ) IC/IB=10 VCE=8V VCE=8V (V f=1.5GHz FE ) Ta=25˚C 200 10 CE(sat) 1 (GHz Ta=75˚C 160 T 8 Ta=75˚C 0.1 120 6 25˚C 25˚C –25˚C 80 4 –25˚C 0.01 40 2 Transition frequency f Forward current transfer ratio h Collector to emitter saturation voltage V 0.001 0 0 0.1 0.3 1 3 10 30 100 0.1 0.3 1 3 10 30 100 1 3 10 30 100 Collector current IC (mA) Collector current IC (mA) Collector current IC (mA) Cob — VCB GUM — IC NF — IC 1.2 12 6 ) f=1MHz VCE=8V VCE=8V IE=0 f=1.5GHz f=1.5GHz (pF Ta=25˚C Ta=25˚C Ta=25˚C 1.0 10 5 ob ) (dB 0.8 8 (dB 4 0.6 6 3 0.4 4 2 Power gain GUM Noise figure NF 0.2 2 1 Collector output capacitance C 0 0 0 1 3 10 30 100 0.1 0.3 1 3 10 30 100 0.1 0.3 1 3 10 30 100 Collector to base voltage VCB (V) Collector current IC (mA) Collector current IC (mA) 2
