Datasheet ELE6A (STMicroelectronics) - 2
Manufacturer | STMicroelectronics |
Description | Automotive Quad-Bands TeseoVI+ GNSS module |
Pages / Page | 9 / 2 — Teseo-ELE6A. Module description. 1.1. Block diagram. Figure 1. Block … |
File Format / Size | PDF / 335 Kb |
Teseo-ELE6A. Module description. 1.1. Block diagram. Figure 1. Block schematic. 1.2. Pin configuration. Figure 2. Module pins layout
Teseo-ELE6A Module description 1 Module description 1.1 Block diagram Figure 1. Block schematic
TCXO RTC - Xtal 32 Mb Flash 32 Mb RAM nReset PP0 STA8610 STANDBY_WAKEUP PPS1 GNSS Core & Subsystem PPS_in Ant_EN Ant_Sense ARM-Cortex-M7 Ant_Short ARM - Cortex-M7 RF_In ESD Connectivity Power SAW Management Main supply (VCC) Sensor IMU UART0 UART1 UART2 SPI I2C JTAG Back-up supply (VBAT) Interrupt
1.2 Pin configuration Figure 2. Module pins layout
54 53 52 51 50 49 48 47 46 45 44 43 42 TS GPIO GND R AKEUP T0_RX T0_TX PPS0_IN nRESET T0_ T0_CTS I2C_CLK / JTRSTn I2C_SDA PPS1_OUT AR AR BY_W UAR UAR U U 1 GND_RF GND 41 AND 2 ANTENNA_IN NC 40 ST 3 PPS0_OUT GND_RF NC 39 4 ANTENNA_SENSE NC 38 5 ANTENNA_EN GND 37 6 ANTENNA_SHORT VBAT 36 7 VCC_RF SYS_STATE 35
Teseo-ELE6A
8 SPI_CLK VCC 34 9 SPI_CS VCC 33 10 SPI_TX GND 32 11 SPI_RX UART1_CTS 31 12 GND_RF UART1_RTS 30 13 GPIO17 NC 29 14 GND GPIO47 28 TS T2_R T2_CTS T2_RX T2_TX T1_RX T1_TX UAR UAR UAR UAR GPIO42 GPIO39 GPIO40 WHEEL_TICK FWD JTDO JTMS UAR UAR 15 16 17 18 19 20 21 22 23 24 25 26 27
DB5474
Rev 2 page 2/9
Document Outline Teseo-ELE6A 1 Module description 1.1 Block diagram 1.2 Pin configuration 1.3 Pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 2.4 Galileo 2.5 IRNSS 2.6 QZSS 3 Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS Revision history
