Datasheet ELE6A (STMicroelectronics) - 6
DescriptionAutomotive Quad-Bands TeseoVI+ GNSS module
Pages / Page9 / 6 — Teseo-ELE6A. Augmentation systems. 3.1. Satellite-based augmentation …
File Format / SizePDF / 335 Kb
Teseo-ELE6A. Augmentation systems. 3.1. Satellite-based augmentation system. 3.2. Differential GPS. DB5474. Rev 2. page 6/9
Teseo-ELE6A Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS DB5474 Rev 2 page 6/9
Teseo-ELE6A Augmentation systems 3 Augmentation systems 3.1 Satellite-based augmentation system
The module supports SBAS. SBAS is a wide area differential GPS (WADGPS), it is a system which provides differential GPS corrections data; SBAS includes the WAAS within the United States, the EGNOS within Europe, the multifunctional transport satellite (MTSAT)–based MSAS within Japan and southeast Asia, and the GPS and GEO augmented navigation (GAGAN) system in India. SBAS data correction is used in the GNSS algorithm to provide a better position estimation. The overall SBAS differential correction mechanism can be conceived as built in 2 phases: • The “acquire and tracking” phase • The “decoding” phase The “acquire and track” phase relates to the capacity of the acquisition engine to reliably track the configured SBAS satellite; during the decoding phase the SBAS message can be decoded to fetch the differential corrections. The current longitude limits for each service are: • WAAS -180°C to -25°C • EGNOS -25°C to +50°C • GAGAN +50°C to +100°C • MSAS +100°C to +180°C The module software with SBAS capability implements a command interface at the NMEA level to allow interaction with the SBAS library. It supports commands to enable/disable the SBAS functionality.
The module supports differential-GPS data according to RTCM 2.3 (radio technical commission for maritime services). Differential-GPS data improves position accuracy.
DB5474
Rev 2 page 6/9
Document Outline Teseo-ELE6A 1 Module description 1.1 Block diagram 1.2 Pin configuration 1.3 Pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 2.4 Galileo 2.5 IRNSS 2.6 QZSS 3 Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS Revision history
