Datasheet FL7921R (ON Semiconductor) - 7
ManufacturerON Semiconductor
DescriptionIntegrated Critical-Mode PFC and Quasi-Resonant Current-Mode PWM Lighting Controller
Pages / Page21 / 7 — FL7921R. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Conditions. Min. …
File Format / SizePDF / 718 Kb
FL7921R. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Conditions. Min. Typ. Max. Unit. Voltage Error Amplifier Section
FL7921R ELECTRICAL CHARACTERISTICS Symbol Parameter Conditions Min Typ Max Unit Voltage Error Amplifier Section
link to page 9
(VDD = 15 V and TA = −40~105C, unless otherwise noted) (continued)
VRATIO Clamp High Output Voltage Ratio (Note 4) VINVH / VREF, 1.06 − 1.14 V/V RANGE = Open VINVH / VREF, 1.04 − 1.08 RANGE = Ground VINV−L Clamp Low Feedback Voltage 2.25 2.35 2.45 V VINV−OVP Over−Voltage Protection for INV Input RANGE = Open − 2.90 2.95 V RANGE = Ground − 2.75 2.80 tINV−OVP Over−Voltage Protection Debounce Time 50 70 90 ms VINV−UVP Under−Voltage Protection for INV Input 0.35 0.45 0.55 V tINV−UVP Under−Voltage Protection Debounce Time 50 70 90 ms VINV−BO PWM and PFC Off Threshold for Brownout 1.15 1.20 1.25 V Protection VCOMP−BO Limited Voltage on COMP Pin for Brownout 1.55 1.60 1.65 V Protection VCOMP Comparator Output High Voltage TA = 25C 4.8 6.0 V VOZ Zero Duty Cycle Voltage on COMP Pin 1.10 1.25 1.40 V ICOMP Comparator Output Source Current VINV = 2.3 V, 15 30 45 mA VCOMP = 1.5 V VINV = 1.5 V, TA = 25C 0.50 0.75 1.00 mA Comparator Output Sink Current RANGE = Open, 20 30 40 mA VINV = 2.75 V, VCOMP = 5 V, TA = 25C RANGE = Ground, 20 30 40 VINV = 2.65 V, VCOMP = 5 V
PFC Current Sense Section
VCSPFC Threshold Voltage for Peak Current VCOMP = 5 V − 0.82 − V Cycle−by−Cycle Limit tPD Propagation Delay − 110 200 ns tBNK Leading−Edge Blanking Time 110 180 250 ns AV CSPFC Compensation Ratio for THD 0.90 0.95 1.00 V/V
PFC Output Section
VZ PFC Gate Output Clamping Voltage VDD = 25 V 14.0 15.5 17.0 V VOL PFC Gate Output Voltage Low VDD = 15 V, IO = 100 mA − − 1.5 V VOH PFC Gate Output Voltage High VDD = 15 V, IO = 100 mA 8 − − V tR PFC Gate Output Rising Time VDD = 12 V, CL = 3 nF, 30 65 100 ns 20~80% tF PFC Gate Output Falling Time VDD = 12 V, CL = 3 nF, 30 50 70 ns 80~20%
PFC Zero−Current Detection Section
VZCD Input Threshold Voltage Rising Edge VZCD Increasing 1.9 2.1 2.3 V VZCD−HYST Threshold Voltage Hysteresis VZCD Decreasing 0.25 0.35 0.45 V VZCD−HIGH Upper Clamp Voltage IZCD = 3 mA 8 10 − V VZCD−LOW Lower Clamp Voltage 0.40 0.65 0.90 V VZCD−SSC Starting Source Current Threshold Voltage 1.3 1.4 1.5 V
www.onsemi.com 7
