Datasheet NCL30001 (ON Semiconductor) - 4
ManufacturerON Semiconductor
DescriptionLED Driver, High Efficiency, Single Stage, Power Factor Corrected
Pages / Page33 / 4 — NCL30001. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. www.onsemi.com
File Format / SizePDF / 405 Kb
NCL30001 MAXIMUM RATINGS Rating Symbol Value Unit www.onsemi.com
(Notes 1 and 2)
Start_up Input Voltage VHV −0.3 to 500 V Start_up Input Current IHV $100 mA Power Supply Input Voltage VCC −0.3 to 20 V Power Supply Input Current ICC $100 mA Latch Input Voltage VLatch −0.3 to 10 V Latch Input Current ILatch $100 mA All Other Pins Voltage −0.3 to 6.5 V All Other Pins Current $100 mA Thermal Resistance, Junction−to−Air qJA C/W 0.1 in” Copper 130 0.5 in” Copper 110 Thermal Resistance, Junction−to−Lead RΘJL 50 C/W Maximum Power Dissipation @ TA = 25C PMAX 0.77 W Operating Temperature Range TJ −40 to 125 C Storage Temperature Range TSTG −55 to 150 C Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. 1. This device contains ESD protection and exceeds the following tests: Pin 1−15: Human Body Model 2000 V per JEDEC Standard JESD22, Method A114E. Machine Model Method 200 V per JEDEC Standard JESD22, Method A114A. Pin 16 is the high voltage startup of the device and is rated to the maximum rating of the part, 500 V. 2. This device contains Latchup protection and exceeds 100 mA per JEDEC Standard JESD78.
www.onsemi.com 4
