Datasheet NCL30001 (ON Semiconductor) - 6
ManufacturerON Semiconductor
DescriptionLED Driver, High Efficiency, Single Stage, Power Factor Corrected
Pages / Page33 / 6 — NCL30001. ELECTRICAL CHARACTERISTICS. Parameter. Test Condition. Symbol. …
File Format / SizePDF / 405 Kb
NCL30001. ELECTRICAL CHARACTERISTICS. Parameter. Test Condition. Symbol. Min. Typ. Max. Unit. OSCILLATOR. AC ERROR AMPLIFIER
NCL30001 ELECTRICAL CHARACTERISTICS Parameter Test Condition Symbol Min Typ Max Unit OSCILLATOR AC ERROR AMPLIFIER
link to page 8 link to page 8
(VCC = 15 V, VAC IN = 3.8 V, VFB = 2.0 V, VFF = 2.4 V, VLatch = open, VISPOS = −100 mV, CDRV = 1 nF, CT = 470 pF, CIAVG = 0.27 nF, CLatch = 0.1 nF, CM = 10 nF, RIAVG = 76.8 kW, RTEST = 50 kW, RRC = 43 kW, For typical Value TJ = 25C, for min/max values TJ = −40C to 125C, unless otherwise noted)
Frequency fosc 90 100 110 kHz Frequency Modulation in Percentage of – 6.8 – % fOSC Frequency Modulation Period – 6.8 – ms Ramp Peak Voltage VCT(peak) – 4.0 – V Ramp Valley Voltage VCT(valley) – 0.10 – V Maximum Duty Ratio RTEST = open D 94 − – % Ramp Compensation Peak Voltage VRCOMP(peak) – 4 – V
AC ERROR AMPLIFIER
Input Offset Voltage (Note 3) Ramp IAVG, VFB = 0 V ACVIO 40 – mV Error Amplifier Transconductance gm – 100 – mS Source Current VAC COMP = 2.0 V, VAC IN = 2.0 V, IEA(source) 25 70 – mA VFF = 1.0 V Sink Current VAC COMP = 2.0 V, VA C_IN = 2.0 V, IEA(sink) −25 −70 – mA VFF = 5.0 V
CURRENT AMPLIFIER
Input Bias Current VISPOS = 0 V CAIbias 40 53 80 mA Input Offset Voltage VAC COMP = 5.0 V, VISpos = 0 V CAVIO −20 0 20 mV Current Limit Threshold force DRV high, VAC COMP = 3.0 V, ramp VILIM 0.695 0.74 0.77 V VISPOS, VRamp_Comp = open Leading Edge Blanking Duration tLEB – 200 – ns Bandwidth – 1.5 – MHz PWM Output Voltage Gain 4 PWMk 4.0 5.3 6.0 V/V PWMk + (VILIM*CAVIO) Current Limit Voltage Gain (See Current V ISVk 15.4 18.5 23 V/V Sense Section) (AVG) ISVK + VISPOS
REFERENCE GENERATOR
Reference Generator Gain V 2 k – 0.55 – V AC_REF @ VFF k + VFB@VAC_IN Reference Generator output voltage VAC IN = 1.2 V, VFF = 0.765 V, RGout1 3.61 4.36 4.94 Vpk (low input ac line and full load) VFB = 4 V Reference Generator output voltage VAC IN = 3.75 V, VFF = 2.39 V, RGout2 1.16 1.35 1.61 Vpk (high input ac line and full load) VFB = 4.0 V Reference Generator output Voltage VAC IN = 1.2 V, VFF = 0.765 V, RGout3 1.85 2.18 2.58 Vpk (low input as line and minimum load) VFB = 2.0 V Reference Generator output voltage VAC IN = 3.75 V, VFF = 2.39 V, RGout4 0.55 0.65 0.78 Vpk (high input ac line and minimum load) VFB = 2.0 V Reference Generator output offset RGoffset −100 – 100 mV voltage Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 3. Guaranteed by Design
www.onsemi.com 6
