Datasheet AWSCR-MTD (Abracon) - 2
Manufacturer | Abracon |
Description | Ceramic resonator 16 MHz 22 pF SMD |
Pages / Page | 4 / 2 — INDUSTRIAL GRADE BUILT-IN CAPACITANCE. CERAMIC RESONATOR. RoHS. … |
File Format / Size | PDF / 1.2 Mb |
INDUSTRIAL GRADE BUILT-IN CAPACITANCE. CERAMIC RESONATOR. RoHS. Compliant. FEATURES:. APPLICATIONS:. ELECTRICAL CHARACTERISTICS:
INDUSTRIAL GRADE BUILT-IN CAPACITANCE CERAMIC RESONATOR
AWSCR-MT Pb in ceramic
RoHS
4.7 x 4.1 x 1.2 mm (exempt per RoHS 2002/95/EC Annex (7))
Compliant
FEATURES: APPLICATIONS:
• Low resonant impedance • Industrial grade • Remote controls, Microprocessor clocks, Mobile • High stability type • Built-in load capacitance phones, DVD & CD-Roms, Electric appliances, • Excellent environmental resistance • Reflow capable Industrial controllers
ELECTRICAL CHARACTERISTICS: It m e q e R i u r n e m e t Frequency Range 8.00MHz to 50.00MHz Resonant Impedance See Table 2.1 Frequency Tolerance and stability See Table 2.1 Withstanding Voltage 50 (DC , 1 min) Rating Voltage (1) D.C.Voltage 6 V.D.C. max
TABLE 2.2
(2) A.C. Voltage 15 Vp-p. max CI=C2 Load Capacitance See Table 2.2 for standard Freq (MHz) pf (±20%) See Option Code for options
8.00~13.00 22
Insulation Resistance 500M min. (10V, 1min)
13.01~16.00 22
Operation Temperature See Table 2.1
16.01~40.00 15
Storage Temperature -55oC to +85oC
40.01~50.00 5
Aging Rate (Fosc) ±0.3% max. (10 years) TABLE 2.1 Part Number Frequency Frequency Resonant Operating (XX.XX denotes Tolerance Stability Impedance Temperature frequency in MHz) at 25ºC at Operating Temp. (
7
) max AWSCR-XX.XXMTS 8.00 MHz - 13.00 MHz 30 13.01 MHz - 50.00 MHz ±0.5% ± 0.3% -20° to +80°C 40 AWSCR-XX.XXMTD 8.00 MHz - 13.00 MHz 30 13.01 MHz - 50.00 MHz ±0.5% ± 0.5% -40° to +85°C 40 AWSCR-XX.XXMTA
EOL
8.00 MHz - 13.00 MHz 30 13.01 MHz - 50.00 MHz ±0.5% ± 0.7% -40° to +125°C 40 TEST CIRCUIT: OPTIONS & PART IDENTIFICATION: (Left blank if standard) AWSCR - Frequency- MT - C - Frequency Packaging
XX.XXMHz T for Tape and Reel 1.Input (1,000pcs/reel) 2.Ground 3.Output IC: 1/6TC4069UBPx2
Operating Temperature Load Capacitance
X: Ceramic resonator
S
-25° to +85°C ex. 5pF-20pF
D
-40° to +85°C
A
-40° to +125°C Contact ABRACON for Load Capacitance options
Parts shall be tested under the condition (Temp.: 20 ±3ºC, Humidity: 65±20% R.H.) unless the standard condition; (Temp.: 25 ±3ºC, Humidity: 65±10% R.H.) is regulated to measure.
Visit www.abracon.com for Terms & Conditions of Sale
Revised: 08.20.07
ABRACON IS ISO 9001 / QS 9000 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED CER tel 949-546-8000 | fax 949-546-8001 | www.abracon.com Document Outline 7020 - ECN-EOL 4636 AWSCR-MT.pdf N_AWSCR-MT.pdf N_AWSCR-MT.pdf
