Datasheet AWSZT-CP (Abracon) - 4
ManufacturerAbracon
Description2-PAD Industrial Grade Ceramic Resonator
Pages / Page4 / 4 — 2-PAD INDUSTRIAL GRADE CERAMIC RESONATOR. 6.0 x 3.0 x 1.7mm. RoHS/RoHS II …
File Format / SizePDF / 646 Kb
2-PAD INDUSTRIAL GRADE CERAMIC RESONATOR. 6.0 x 3.0 x 1.7mm. RoHS/RoHS II Compliant. Pb in ceramic, exemption (7c-1). CAUTION
2-PAD INDUSTRIAL GRADE CERAMIC RESONATOR 6.0 x 3.0 x 1.7mm RoHS/RoHS II Compliant Pb in ceramic, exemption (7c-1) CAUTION
AWSZT-CP SERIES
6.0 x 3.0 x 1.7mm RoHS/RoHS II Compliant Pb in ceramic, exemption (7c-1) CAUTION MSL = 1
1. Don’t apply excess mechanical stress to the component and terminals at soldering. Do not use this product with bend. 2. Do not clean or wash the component for it is not hermetically sealed. 3. Do not use strong acidity flux, more than 0.2wt% chlorine content, in flow soldering. 4. Don’t be close to fire. 5. This specification mentions the quality of the component as a single unit. Please insure the component is thoroughly evaluated in your application circuit 6. Expire date (Shelf life) of the products is 12 months after delivery under the conditions of a sealed and an unopened package. Please use the products within 12 months after delivery. If you store the products for a long time (more than 12 months), use carefully because the products may be degraded in the solderability or rusty. Please confirm solderability and characteristics for the products regularly.
NOTES
1. The parts are manufactured in accordance with this specification. If other conditions and specifications which are required for this specification, please contact ABRACON for more information. 2. ABRACON will supply the parts in accordance with this specification unless we receive a written request to modify prior to an order placement. 3. In no case shall ABRACON be liable for any product failure from in appropriate handling or operation of the item beyond the scope of this specification. 4. When changing your production process, please notify ABRACON immediately. 5. ABRACON’s products are COTS – Commercial-Off-The-Shelf products; suitable for Commercial, Industrial and, where designated, Automotive Applications. ABRACON’s products are not specifically designed for Military, Aviation, Aerospace, Life-dependant Medical applications or any application requiring high reliability where component failure could result in loss of life and/or property. For applications requiring high reliability and/or presenting an extreme operating environment, written consent and authorization from ABRACON is required. Please contact ABRACON for more information. 6. All specifications and Marking will be subject to change without notice.
REVISED: 12.19.2016
5101 Hidden Creek Ln Spicewood TX 78669 ABRACON IS Phone: 512-371-6159 | Fax: 512-351-8858 ISO9001-2008 For terms and conditions of sales, please visit:
LLC
CERTIFIED www.abracon.com
