Datasheet MSPM0C110, MSPS003 (Texas Instruments) - 3
Description | Mixed-Signal Microcontrollers |
Pages / Page | 69 / 3 — MSPM0C1104. , MSPM0C1103. www.ti.com. 4 Functional Block Diagram. TI … |
File Format / Size | PDF / 2.2 Mb |
MSPM0C1104. , MSPM0C1103. www.ti.com. 4 Functional Block Diagram. TI MSPM0C110x Microcontrollers. Legend
MSPM0C1104 , MSPM0C1103 www.ti.com
SLASF90C – OCTOBER 2023 – REVISED FEBRUARY 2025
PAx
ULPCLK GPIO CRC CPU Subsystem Up to 18 16-bit K) 32-bit Arm ROM BCR Cortex-M0+ Flash DMA fmax = 24MHz Up to 16KB 1-ch us (MCL s (MCLK NVIC ral Bu SWD AHB B SRAM POCI, PICO, SPI0 1KB SCK, CSx riphe Temperature Sensor CPU-Only PD1 Peripheral Bus (MCLK) PD1 Pe 10-Channel ADC0 (External) 12-bit A0_x ULPCLK SWCLK, VREF DEBUG SWDIO to ADC LK) LK) TX, RX, EVENT UART0 IOMUX FLASHCTL CTS, RTS 1-channel s (ULPC s (ULPC 4-Channel SDA, SCL I2C0 PMCU (SYSCTL) TIMA0 ral Bu ral Bu FAULT riphe riphe CKM PMU BEEP BEEPER TIMG14 4-Channel PD0 Pe LFOSC LDO PD0 Pe SYSOSC BOR 2-Channel WWDT0 TIMG8 QEI/HALL POR
Legend
PD1, CPU Access Only HFCLK_IN VDD, VSS PD1, CPU/DMA Access LFCLK_IN NRST CLK_OUT PD1/PD0, CPU/DMA Access PD0, CPU/DMA Access
Figure 4-1. MSPM0C110x Functional Block Diagram
Copyright © 2025 Texas Instruments Incorporated Submit Document Feedback 3 Product Folder Links: MSPM0C1104 MSPM0C1103 Document Outline 1 Features 2 Applications 3 Description 4 Functional Block Diagram Table of Contents 5 Device Comparison 6 Pin Configuration and Functions 6.1 Pin Diagrams 6.2 Pin Attributes 6.3 Signal Descriptions 6.4 Connections for Unused Pins 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Supply Current Characteristics 7.5.1 RUN/SLEEP Modes 7.5.2 STOP/STANDBY Modes 7.5.3 SHUTDOWN Mode 7.6 Power Supply Sequencing 7.6.1 POR and BOR 7.6.2 Power Supply Ramp 7.7 Flash Memory Characteristics 7.8 Timing Characteristics 7.9 Clock Specifications 7.9.1 System Oscillator (SYSOSC) 7.9.2 Low Frequency Oscillator (LFOSC) 7.10 Digital IO 7.10.1 Electrical Characteristics 7.10.2 Switching Characteristics 7.11 ADC 7.11.1 Electrical Characteristics 7.11.2 Switching Characteristics 7.11.3 Linearity Parameters 7.11.4 Typical Connection Diagram 7.12 Temperature Sensor 7.13 VREF 7.13.1 Voltage Characteristics 7.13.2 Electrical Characteristics 7.14 I2C 7.14.1 I2C Characteristics 7.14.2 I2C Filter 7.14.3 I2C Timing Diagram 7.15 SPI 7.15.1 SPI 7.15.2 SPI Timing Diagrams 7.16 UART 7.17 TIMx 7.18 Windowed Watchdog Characteristics 7.19 Emulation and Debug 7.19.1 SWD Timing 8 Detailed Description 8.1 CPU 8.2 Operating Modes 8.2.1 Functionality by Operating Mode (MSPM0C110x) 8.3 Power Management Unit (PMU) 8.4 Clock Module (CKM) 8.5 DMA 8.6 Events 8.7 Memory 8.7.1 Memory Organization 8.7.2 Peripheral File Map 8.7.3 Peripheral Interrupt Vector 8.8 Flash Memory 8.9 SRAM 8.10 GPIO 8.11 IOMUX 8.12 ADC 8.13 Temperature Sensor 8.14 VREF 8.15 CRC 8.16 UART 8.17 SPI 8.18 I2C 8.19 WWDT 8.20 Timers (TIMx) 8.21 Device Analog Connections 8.22 Input/Output Diagrams 8.23 Serial Wire Debug Interface 8.24 Device Factory Constants 8.25 Identification 9 Applications, Implementation, and Layout 9.1 Typical Application 9.1.1 Schematic 10 Device and Documentation Support 10.1 Device Nomenclature 10.2 Tools and Software 10.3 Support Resources 10.4 Trademarks 10.5 Electrostatic Discharge Caution 10.6 Glossary 11 Revision History 12 Mechanical, Packaging, and Orderable Information
