Datasheet OPA206, OPA2206, OPA4206 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionInput-overvoltage-protected, low-power, low-noise four-channel op amp with super-beta inputs
Pages / Page48 / 1 — OPA206. , OPA2206. , OPA4206. OPAx206 Input-Overvoltage-Protected, 4-µV, …
File Format / SizePDF / 3.3 Mb
OPA206. , OPA2206. , OPA4206. OPAx206 Input-Overvoltage-Protected, 4-µV, 0.08-µV/°C, Low-Power
Datasheet OPA206, OPA2206, OPA4206 Texas Instruments
link to page 1 link to page 31
OPA206 , OPA2206 , OPA4206
SBOSA11E – MARCH 2020 – REVISED DECEMBER 2023
OPAx206 Input-Overvoltage-Protected, 4-µV, 0.08-µV/°C, Low-Power Super Beta, e-trim™ Operational Amplifiers 1 Features 3 Description
• Integrated input overvoltage protection up to ±40 V The OPA206, OPA2206, and OPA4206 (OPAx206) beyond supplies are the next generation of the industry-standard • e-trim™ operational amplifier performance OPAx277 family with the added feature of input – Low offset voltage: 25 µV (max) overvoltage protection. These precision, bipolar, – Low offset voltage drift: ±0.5 µV/°C (max) e‑trim™ op amps with super-beta inputs use TI’s • Super beta inputs proprietary trimming technology to achieve an input – Input bias current: 500 pA (max) offset voltage of ±4 μV (typical) and an input offset – Input current noise: 110 fA/√Hz voltage drift of ±0.08 μV/°C (typical). The input • Low noise overvoltage protection activates when the input signal – 0.1-Hz to 10-Hz: 0.2 µV exceeds the supply range and protects up to 40 V PP – Voltage noise: 8 nV/√Hz beyond either supply. This feature eliminates the need • A for external circuitry to prevent amplifier damage, OL, CMRR, and PSRR: > 124 dB (full temperature range) thereby reducing size and costs. • Gain bandwidth product: 3.6 MHz The OPAx206 provide a speed-to-power ratio of • Low quiescent current: 240 µA (max) 3.6 MHz for a mere 220 μA (typical). These devices • Slew rate: 4 V/µs also achieve a low voltage noise density of only • Overload power limiter 8 nV/√Hz at 1 kHz. The super-beta inputs of the • Rail-to-rail output OPAx206 have a very low input bias current of 100 pA • EMI and RFI filtered inputs (typical) and a current noise density of 110 fA/√Hz. • Wide supply: 4.5 V to 36 V • Temperature range: –40°C to +125°C The high performance of the OPAx206 make these devices an excellent choice for systems requiring
2 Applications
high precision and low power consumption, such as • Analog input module high-density analog input modules in programmable • Mixed module (AI,AO,DI,DO) logic controllers, field and portable instrumentation • Lab and field Instrumentation systems, and source measurement units. The • Source measurement unit (SMU) OPA205 and OPA2205 are related devices with the • Digital multimeter (DMM) same op amp core without the input protection, but • Train control and management with improved broadband noise (7.2 nV/√Hz). • String inverter
Device Information
• Data acquisition (DAQ)
PART NUMBER CHANNELS PACKAGE
(1) OPA206 Single D (SOIC, 8) 7.5 D (SOIC, 8) OPA2206 Dual 5 DGK (VSSOP, 8) A) D (SOIC, 14) OPA4206 Quad 2.5 PW (TSSOP, 14) rent (m 0 (1) For more information, see Section 11. 80 k 20 k -2.5 ±10 V 12 V Input Bias Cur TA = –40°C 12 V -5 T 2.2 nF A = 25°C TA = 85°C 100 nF TA = 125°C 100 nF -7.5 GND -60 -40 -20 0 20 40 60 GND – 3.74 k 11.8 k 6.65 k Common-mode Voltage (V) – Output +
OPA2206
2 V +
OPA2206 OPAx206 Input Overvoltage Protection
2.2 nF 330 pF 100 nF 100 nF 12 V 12 V GND GND GND GND
OPAx206 Typical Application
An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information: OPA206 5.5 Thermal Information: OPA2206 5.6 Thermal Information: OPA4206 5.7 Electrical Characteristics: VS = ±5 V 5.8 Electrical Characteristics: VS = ±15 V 5.9 Typical Characteristics 6 Parameter Measurement Information 6.1 Typical Specifications and Distributions 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Input Overvoltage Protection 7.3.2 Input Offset Trimming 7.3.3 Lower Input Bias With Super-Beta Inputs 7.3.4 Overload Power Limiter 7.3.5 EMI Rejection 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 Voltage Attenuator 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 8.2.2 Discrete, Two-Op-Amp Instrumentation Amplifier 8.2.3 Input Buffer and Protection for ADC Driver 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Device Support 9.1.1 Development Support 9.1.1.1 PSpice® for TI 9.2 Documentation Support 9.2.1 Related Documentation 9.3 Receiving Notification of Documentation Updates 9.4 Support Resources 9.5 Trademarks 9.6 Electrostatic Discharge Caution 9.7 Glossary 10 Revision History 11 Mechanical, Packaging, and Orderable Information
