Datasheet LTC4151 (Analog Devices) - 5
DescriptionHigh Voltage I2C Current and Voltage Monitor
Pages / Page18 / 5 — Typical perForMance characTerisTics VIN = 12V, TA = 25°C, unless noted. …
File Format / SizePDF / 446 Kb
Typical perForMance characTerisTics VIN = 12V, TA = 25°C, unless noted. Supply Current vs Supply Voltage. (Normal Mode)
Typical perForMance characTerisTics VIN = 12V, TA = 25°C, unless noted Supply Current vs Supply Voltage (Normal Mode)
LTC4151
Typical perForMance characTerisTics VIN = 12V, TA = 25°C, unless noted. Supply Current vs Supply Voltage Supply Current vs Supply Voltage (Normal Mode) (Shutdown Mode)
1.30 400 1.15 – 40°C 300 – 40°C 25°C 1.00 25°C 85°C 200 85°C SUPPLY CURRENT (mA) 0.85 SUPPLY CURRENT (µA) 100 0.70 0 0 20 40 60 80 0 20 40 60 80 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) 4151 G01 4151 G02
ADC Total Unadjusted Error vs Code (ADIN Voltage) ADC DNL vs Code (ADIN Voltage) ADC INL vs Code (ADIN Voltage)
0.10 1.0 1.0 0.05 0.5 0.5 0 0 0 ADC DNL (LSB) ADC INL (LSB) –0.05 –0.5 –0.5 ADC TOTAL UNADJUSTED ERROR (%) –0.10 –1.0 –1.0 0 1024 2048 3072 4096 0 1024 2048 3072 4096 0 1024 2048 3072 4096 CODE CODE CODE 4151 G03 4151 G04 4151 G05
ADC Total Unadjusted Error vs Code (SENSE Voltage) ADC DNL vs Code (SENSE Voltage) ADC INL vs Code (SENSE Voltage)
1.0 2 2 0.5 1 1 0 0 0 ADC DNL (LSB) ADC INL (LSB) –0.5 –1 –1 ADC TOTAL UNADJUSTED ERROR (%) –1.0 –2 –2 0 1024 2048 3072 4096 0 1024 2048 3072 4096 0 1024 2048 3072 4096 CODE CODE CODE 4151 G06 4151 G07 4151 G08 4151ff For more information www.linear.com/LTC4151 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Package Description Revision History Typical Application Related Parts
