Datasheet KA317, LM317 (Fairchild) - 3
Manufacturer | Fairchild |
Description | 3-Terminal Positive Adjustable Regulator |
Pages / Page | 7 / 3 — VI-VO = 5 V, IO = 0.5 A, 0°C ≤ TJ ≤ +125°C, IMAX = 1.5 A, PDMAX = 20 W, … |
File Format / Size | PDF / 237 Kb |
VI-VO = 5 V, IO = 0.5 A, 0°C ≤ TJ ≤ +125°C, IMAX = 1.5 A, PDMAX = 20 W, unless otherwise specified. Symbol
RLINE RLOAD Parameter
Line Regulation(1) Load Regulation(1) Conditions Typ. Max. TA = +25°C, 3 V ≤ VI -VO ≤ 40 V 0.01 0.04 3 V ≤ VI -VO ≤ 40 V 0.02 0.07 VO < 5 V 18 25 mV VO ≥ 5 V 0.4 0.5 %/VO VO < 5 V 40 70 mV VO ≥ 5 V 0.8 1.5 %/VO 46 100 μA 2.0 5.0 μA 1.25 1.30 V TA = +25°C,
10mA ≤ IO ≤ IMAX
10 mA ≤ IO ≤ IMAX IADJ Adjustable Pin Current ΔIADJ Adjustable Pin Current
Change 3 V ≤ VI -VO ≤ 40 V,
10 mA ≤ IO ≤ IMAX, PD ≤ PMAX VREF Reference Voltage 3 V ≤ VIN -VO ≤ 40 V,
10 mA ≤ IO ≤ IMAX, PD ≤ PMAX STT Temperature Stability IL(MIN) Minimum Load Current
to Maintain Regulation VI -VO = 40 V 3.5
VI -VO ≤ 15 V,
PD ≤ PMAX TA = 25°C eN RMS Noise,% of VOUT TA = +25°C, 10 Hz ≤ f ≤ 10 kHz RR Ripple Rejection(2) VO = 10 V,
f = 120 Hz ST Long-Term Stability,
TJ = THIGH 1.20 0.7 Maximum Output
Current IO(MAX) Min. 1.5 %/VO
12.0 mA 2.2
0.3
0.003 without CADJ TA = +25°C for End Point
Measurements, 1000 HR %/ V A VI -VO ≤ 40 V,
PD ≤ PMAX CADJ = 10 μF Unit 0.010 %/VO 60
dB
66 75
0.3 1.0 % Notes:
1. Load and line regulation are specified at constant junction temperature. Change in VD due to heating effects must be
taken into account separately. Pulse testing with low duty is used (PMAX = 20 W).
2. CADJ, when used, is connected between the adjustment pin and ground. © 2002 Fairchild Semiconductor Corporation
KA317 / LM317 Rev. 1.2.2 www.fairchildsemi.com
3 KA317 / LM317 — 3-Terminal Positive Adjustable Regulator Electrical Characteristics
