Datasheet LM317 (Fairchild) - 3
ManufacturerFairchild
Description3-Terminal Positive Adjustable Regulator
Pages / Page5 / 3 — LM317. Typical Performance Characteristics. FIGURE 1. Load Regulation. …
File Format / SizePDF / 904 Kb
LM317. Typical Performance Characteristics. FIGURE 1. Load Regulation. FIGURE 2. Adjustment Current. FIGURE 3. Dropout Voltage
LM317 Typical Performance Characteristics FIGURE 1 Load Regulation FIGURE 2 Adjustment Current FIGURE 3 Dropout Voltage
LM317
LM317 Typical Performance Characteristics FIGURE 1. Load Regulation FIGURE 2. Adjustment Current FIGURE 3. Dropout Voltage FIGURE 4. Reference Voltage Typical Application Note:
Ci is required when regulator is located an appreciable distance from power supply filter.
Note:
Co is not needed for stability, however, it does improve transient response.
Note:
Since IADJ is controlled to less than 100PA, the error associated with this term is negligible in most applications.
FIGURE 5. Programmable Regulator
3 www.fairchildsemi.com
