Datasheet AD7621 (Analog Devices) - 3
Description16-Bit, 2 LSB INL, 3 MSPS PulSAR® ADC
Pages / Page32 / 3 — AD7621. SPECIFICATIONS. Table 2. Parameter Conditions. Min. Typ. Max. Unit
File Format / SizePDF / 627 Kb
AD7621 SPECIFICATIONS Table 2 Parameter Conditions Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
AVDD = DVDD = 2.5 V; OVDD = 2.3 V to 3.6 V; VREF = 2.5 V; all specifications TMIN to TMAX, unless otherwise noted.
Table 2. Parameter Conditions Min Typ Max Unit
RESOLUTION 16 Bits ANALOG INPUT Voltage Range VIN+ − VIN− −VREF VREF V Operating Input Voltage VIN+, VIN− to AGND −0.1 AVDD1 V Analog Input CMRR fIN = 100 kHz 55 dB Input Current 3 MSPS throughput 25 μA Input Impedance2 THROUGHPUT SPEED Complete Cycle Wideband warp, warp modes 333 ns Throughput Rate Wideband warp, warp modes 0.001 3 MSPS Time Between Conversions Wideband warp, warp modes 1 ms Complete Cycle Normal mode 500 ns Throughput Rate Normal mode 0 2 MSPS Complete Cycle Impulse mode 800 ns Throughput Rate Impulse mode 0 1.25 MSPS DC ACCURACY All modes Integral Linearity Error3 VREF = 2.048 V, PDREF = high −2 ±1 +2 LSB4 No Missing Codes VREF = 2.048 V, PDREF = high 16 Bits Differential Linearity Error VREF = 2.048 V, PDREF = high −1 +2 LSB Transition Noise VREF = 2.5 V 0.69 LSB Transition Noise VREF = 2.048 V 0.82 LSB Zero Error, T 5 MIN to TMAX −30 +30 LSB Zero Error Temperature Drift ±1 ppm/°C Gain Error, T 5 MIN to TMAX −0.38 +0.38 % of FSR Gain Error Temperature Drift ±2 ppm/°C Power Supply Sensitivity AVDD = 2.5 V ± 5% ±3 LSB AC ACCURACY Dynamic Range fIN = 20 kHz, VREF = 2.5 V 90.5 dB6 Signal-to-Noise fIN = 20 kHz, VREF = 2.5 V 88 90 dB fIN = 20 kHz, VREF = 2.048 V 86 88 dB fIN = 100 kHz, VREF = 2.5 V 89.2 dB Spurious-Free Dynamic Range fIN = 20 kHz 103 dB fIN = 100 kHz 101 dB Total Harmonic Distortion fIN = 20 kHz –102 dB fIN = 100 kHz −100 dB Signal-to-(Noise + Distortion) fIN = 20 kHz, VREF = 2.5 V 87.5 89.8 dB fIN = 20 kHz, VREF = 2.048 V 87.5 dB fIN = 100 kHz, VREF = 2.5 V 89 dB –3 dB Input Bandwidth 50 MHz SAMPLING DYNAMICS Aperture Delay 1 ns Aperture Jitter 5 ps rms Transient Response Full-scale step 50 ns INTERNAL REFERENCE PDREF = PDBUF = low Output Voltage REF @ 25°C 2.038 2.048 2.058 V Temperature Drift –40°C to +85°C ±7 ppm/°C Line Regulation AVDD = 2.5 V ± 5% ±15 ppm/V Rev. 0 | Page 3 of 32 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS SERIAL CLOCK TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION MODES OF OPERATION TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE Single-to-Differential Driver VOLTAGE REFERENCE INPUT Internal Reference External 1.2 V Reference and Internal Buffer External Reference Reference Decoupling Temperature Sensor POWER SUPPLY Power Sequencing Power-Up POWER DISSIPATION VS. THROUGHPUT CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read After Conversion External Clock Data Read During Previous Conversion MICROPROCESSOR INTERFACING SPI Interface (ADSP-219x) APPLICATION LAYOUT EVALUATING THE AD7621 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
