Datasheet AD9680 (Analog Devices) - 9
Description14-Bit, 1.25 GSPS/1 GSPS/820 MSPS/500 MSPS JESD204B, Dual Analog-to-Digital Converter
Pages / Page91 / 9 — Data Sheet. AD9680. SWITCHING SPECIFICATIONS. Table 4. AD9680-500 …
RevisionE
File Format / SizePDF / 4.0 Mb
Data Sheet. AD9680. SWITCHING SPECIFICATIONS. Table 4. AD9680-500 AD9680-820 AD9680-1000. Parameter. Temperature Min Typ Max Min. Typ
Data Sheet AD9680 SWITCHING SPECIFICATIONS Table 4 AD9680-500 AD9680-820 AD9680-1000 Parameter Temperature Min Typ Max Min Typ
link to page 10 link to page 10 link to page 10 link to page 10
AVDD1 = 1.25 V, AVDD2 = 2.5 V, AVDD3 = 3.3 V, AVDD1_SR = 1.25 V, DVDD = 1.25 V, DRVDD = 1.25 V, SPIVDD = 1.8 V, specified maximum sampling rate for each speed grade, AIN = −1.0 dBFS, default SPI settings, TA = 25°C, unless otherwise noted.
Table 4. AD9680-500 AD9680-820 AD9680-1000 Parameter Temperature Min Typ Max Min Typ Max Min Typ Max Unit
CLOCK Clock Rate (at CLK+/CLK− Pins) Full 0.3 4 0.3 4 0.3 4 GHz Maximum Sample Rate1 Full 500 820 1000 MSPS Minimum Sample Rate2 Full 300 300 300 MSPS Clock Pulse Width High Full 1000 609.756 500 ps Clock Pulse Width Low Full 1000 609.756 500 ps OUTPUT PARAMETERS Unit Interval (UI)3 Full 80 200 80 121.95 80 100 ps Rise Time (tR) (20% to 80% into 100 Ω Load) 25°C 24 32 24 32 24 32 ps Fall Time (tF) (20% to 80% into 100 Ω Load) 25°C 24 32 24 32 24 32 ps PLL Lock Time 25°C 2 2 2 ms Data Rate per Channel (NRZ)4 25°C 3.125 5 12.5 3.125 8.2 12.5 3.125 10 12.5 Gbps LATENCY5 Pipeline Latency Full 55 55 55 Clock cycles Fast Detect Latency Full 28 28 28 Clock cycles Wake-Up Time6 Standby 25°C 1 1 1 ms Power-Down 25°C 4 4 4 ms APERTURE Aperture Delay (tA) Full 530 530 530 ps Aperture Uncertainty (Jitter, tj) Full 55 55 55 fs rms Out-of-Range Recovery Time Full 1 1 1 Clock Cycles 1 The maximum sample rate is the clock rate after the divider. 2 The minimum sample rate operates at 300 MSPS with L = 2 or L = 1. 3 Baud rate = 1/UI. A subset of this range can be supported. 4 Default L = 4. This number can be changed based on the sample rate and decimation ratio. 5 No DDCs used. L = 4, M = 2, F = 1. 6 Wake-up time is defined as the time required to return to normal operation from power-down mode.
TIMING SPECIFICATIONS Table 5. Parameter Test Conditions/Comments Min Typ Max Unit
CLK+ to SYSREF+ TIMING REQUIREMENTS See Figure 3 tSU_SR Device clock to SYSREF+ setup time 117 ps tH_SR Device clock to SYSREF+ hold time −96 ps SPI TIMING REQUIREMENTS See Figure 4 tDS Setup time between the data and the rising edge of SCLK 2 ns tDH Hold time between the data and the rising edge of SCLK 2 ns tCLK Period of the SCLK 40 ns tS Setup time between CSB and SCLK 2 ns tH Hold time between CSB and SCLK 2 ns tHIGH Minimum period that SCLK must be in a logic high state 10 ns tLOW Minimum period that SCLK must be in a logic low state 10 ns tEN_SDIO Time required for the SDIO pin to switch from an input to an 10 ns output relative to the SCLK falling edge (not shown in Figure 4) tDIS_SDIO Time required for the SDIO pin to switch from an output to an 10 ns input relative to the SCLK rising edge (not shown in Figure 4) Rev. B | Page 9 of 91 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9680-1000 AD9680-820 AD9680-500 EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Differential Input Configurations Input Common Mode Analog Input Buffer Controls and SFDR Optimization Input Buffer Control Registers (0x018, 0x019, 0x01A, 0x935, 0x934, 0x11A) Absolute Maximum Input Swing VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Input Clock Divider Input Clock Divider ½ Period Delay Adjust Clock Fine Delay Adjust Clock Jitter Considerations Power-Down/Standby Mode Temperature Diode ADC OVERRANGE AND FAST DETECT ADC OVERRANGE FAST THRESHOLD DETECTION (FD_A AND FD_B) SIGNAL MONITOR SPORT OVER JESD204B DIGITAL DOWNCONVERTER (DDC) DDC I/Q INPUT SELECTION DDC I/Q OUTPUT SELECTION DDC GENERAL DESCRIPTION FREQUENCY TRANSLATION GENERAL DESCRIPTION Variable IF Mode 0 Hz IF (ZIF) Mode fS/4 Hz IF Mode Test Mode DDC NCO PLUS MIXER LOSS AND SFDR NUMERICALLY CONTROLLED OSCILLATOR Setting Up the NCO FTW and POW NCO Synchronization Mixer FIR FILTERS GENERAL DESCRIPTION HALF-BAND FILTERS HB4 Filter HB3 Filter HB2 Filter HB1 Filter DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION DDC EXAMPLE CONFIGURATIONS DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE JESD204B OVERVIEW FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) and SYNCINB± Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8-Bit/10-Bit Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls De-Emphasis Phase-Locked Loop JESD204B TX CONVERTER MAPPING CONFIGURING THE JESD204B LINK Example 1: Full Bandwidth Mode Example 2: ADC with DDC Option (Two ADCs Plus Four DDCs) MULTICHIP SYNCHRONIZATION SYSREF± SETUP/HOLD WINDOW MONITOR TEST MODES ADC TEST MODES JESD204B BLOCK TEST MODES Transport Layer Sample Test Mode Interface Test Modes Data Link Layer Test Modes SERIAL PORT INTERFACE CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open and Reserved Locations Default Values Logic Levels Channel-Specific Registers SPI Soft Reset MEMORY MAP REGISTER TABLE APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS AVDD1_SR (PIN 57) AND AGND (PIN 56 AND PIN 60) OUTLINE DIMENSIONS ORDERING GUIDE
