Datasheet AD812 (Analog Devices) - 4
DescriptionDual, Current Feedback Low Power Op Amp
Pages / Page16 / 4 — AD812–SPECIFICATIONS Single Supply (Continued). AD812A. Model. …
RevisionB
File Format / SizePDF / 382 Kb
AD812–SPECIFICATIONS Single Supply (Continued). AD812A. Model. Conditions. Min. Typ. Max. Units
AD812–SPECIFICATIONS Single Supply (Continued) AD812A Model Conditions Min Typ Max Units
AD812–SPECIFICATIONS Single Supply (Continued) AD812A Model Conditions V Min Typ Max Units S
DC PERFORMANCE Input Offset Voltage +5 V, +3 V 1.5 4.5 mV T –T 7.0 mV MIN MAX Offset Drift +5 V, +3 V 7 µV/°C –Input Bias Current +5 V, +3 V 2 20 µA T –T 30 µA MIN MAX +Input Bias Current +5 V, +3 V 0.2 1.5 µA T –T 2.0 µA MIN MAX Open-Loop Voltage Gain V = +2.5 V p-p +5 V 67 73 dB O V = +0.7 V p-p +3 V 70 dB O Open-Loop Transresistance V = +2.5 V p-p +5 V 250 400 kΩ O V = +0.7 V p-p +3 V 300 kΩ O INPUT CHARACTERISTICS Input Resistance +Input +5 V 15 MΩ –Input +5 V 90 Ω Input Capacitance +Input 2 pF Input Common Mode +5 V 1.0 4.0 V Voltage Range +3 V 1.0 2.0 V Common-Mode Rejection Ratio Input Offset Voltage V = 1.25 V to 3.75 V +5 V 52 55 dB CM –Input Current 3 5.5 µA/V +Input Current 0.1 0.2 µA/V Input Offset Voltage V = 1 V to 2 V +3 V 52 dB CM –Input Current 3.5 µA/V +Input Current 0.1 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing p-p R = 1 kΩ, T –T +5 V 3.0 3.2 V p-p L MIN MAX R = 150 Ω, T –T +5 V 2.8 3.1 V p-p L MIN MAX +3 V 1.0 1.3 V p-p Output Current +5 V 20 30 mA +3 V 15 25 mA Short Circuit Current G = +2, R = 715 Ω +5 V 40 mA F V = 1 V IN MATCHING CHARACTERISTICS Dynamic Crosstalk G = +2, f = 5 MHz +5 V, +3 V –72 dB Gain Flatness Match G = +2, f = 20 MHz +5 V, +3 V 0.1 dB DC Input offset Voltage T –T +5 V, +3 V 0.5 3.5 mV MIN MAX –Input Bias Current T –T +5 V, +3 V 2 25 µA MIN MAX POWER SUPPLY Operating Range 2.4 36 V Quiescent Current Per Amplifier +5 V 3.2 4.0 mA +3 V 3.0 3.5 mA T –T +5 V 4.5 mA MIN MAX Power Supply Rejection Ratio Input Offset Voltage V = +3 V to +30 V 70 80 dB S –Input Current 0.3 0.6 µA/V +Input Current 0.005 0.05 µA/V TRANSISTOR COUNT 56 NOTES 1Slew rate measurement is based on 10% to 90% rise time in the specified closed-loop gain. 2Single supply differential gain and phase are measured with the ac coupled circuit of Figure 53. Specifications subject to change without notice. –4– REV. B
