Datasheet AD8675 (Analog Devices) - 6
Description36 V Precision, 2.8 nV/√Hz Rail-to-Rail Output Op Amp
Pages / Page12 / 6 — AD8675. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 150. VS = ±15V. …
RevisionE
File Format / SizePDF / 303 Kb
AD8675. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 150. VS = ±15V. 100. Y (n. T SI. TYPICAL. OSV. ISE D O. –50. E N G. A T L. –100. –150. –40. –20
AD8675 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 150 VS = ±15V 100 Y (n T SI TYPICAL OSV ISE D O –50 E N G A T L –100 –150 –40 –20
±15 V and ±5 V, TA = 25°C, unless otherwise specified.
10 150 VS = ±15V 9 ) 100 Hz 8 V/ 7 Y (n 50 T SI 6 TYPICAL V) EN 0 5 OSV ISE D O 4 –50 E N G 3 A T L 2 –100 VO 1 –150 0 –40 –20 0 20 40 60 80 100 120
005
1 10 100 1k 10k 100k
011
TEMPERATURE (°C)
05564-
FREQUENCY (Hz)
05564- Figure 3. Voltage Noise Density vs. Frequency Figure 6. Offset Voltage vs. Temperature
90 350 80 300 70 RS RS 250 IE 60 IE IF IF L L P P 50 200 AM AM F F 40 R O 150 R O BE 30 BE 100 NUM NUM 20 50 10 0 0 –100 –80 –60 –40 –20 0 20 40 60 80 100 –2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0
016 006
VOS (µV) IB (nA)
05564- 05564- Figure 4. Input Offset Voltage Distribution Figure 7. Input Bias Current, VS = ±15 V
25 350 300 20 RS RS 250 IE IE IF IF L L 15 P P 200 AM AM F F 150 R O R O 10 BE BE 100 NUM NUM 5 50 0 0 –2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0
008
0 05 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 00 IB (nA)
05564-
0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 1.
014
TCVOS (µV/°C)
05564- Figure 5. TCVOS Figure 8. Input Bias Current, VS = ±5 V Rev. E | Page 6 of 12 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance Power Sequencing ESD Caution Typical Performance Characteristics Test Circuit Outline Dimensions Ordering Guide
