Datasheet AD8676 (Analog Devices) - 6
Description | Ultra Precision, 36 V, 2.8 nV/√Hz Dual RRO Op Amp |
Pages / Page | 12 / 6 — AD8676. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 150. VS = ±15V. … |
Revision | C |
File Format / Size | PDF / 345 Kb |
AD8676. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 150. VS = ±15V. z) H. 100. V/ n (. T SI. TYPICAL. E IS. OSV. N E. –50. A T L. –100. –150. 10k
AD8676 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
±15 V and ±5 V, TA = 25°C, unless otherwise specified.
10 150 VS = ±15V 9 z) H 100 8 V/ n ( 7 Y 50 T SI 6 TYPICAL EN V) D 5 (µ 0 E IS OSV O 4 N E –50 G 3 A T L 2 VO –100 1 0 –150 1 10 100 1k 10k 100k
3 06 00
–40 –20 0 20 40 60 80 100 120
1 7- 7-
FREQUENCY (Hz)
48
TEMPERATURE (°C)
48 06 06 Figure 3. Voltage Noise Density vs. Frequency Figure 6. Offset Voltage vs. Temperature
90 350 80 300 70 S R RS 250 IE 60 IE IF L IF P L P M 50 200 M A A F OF 40 R 150 E R O BE MB 30 U N 10 NUM 20 50 10 0 0 –100 –80 –60 –40 –20 0 20 40 60 80 100
04
–2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0
07 0 1 7- 7-
VOS (µV)
48
I
48
B (nA)
06 06 Figure 4. Input Offset Voltage Distribution Figure 7. Input Bias Current, VSY = ±15 V
25 350 300 20 S R RS 250 IE IE IF L IF 15 P L P M 200 M A A F OF R 10 150 E R O B BE M U N 10 NUM 5 50 0 0 0 05 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 00 –2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0
08 5 1
0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 1.
7- 00 7-
I
48
T B (nA) CVOS (µV/°C)
48 06 06 Figure 5. TCVOS Distribution Figure 8. Input Bias Current, VSY = ±5 V Rev. C | Page 6 of 12 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
